Old 09-07-2013, 03:15 PM   #1
1988 25' Excella
Trumbull , Connecticut
Washing an Airstream!
Hello fellow Streamers
Getting ready for a trip and the old stream has been stored outside for a few years and it needs a good washing. There is some gren algee on parts of it not thick stuff but a green haze. What is recommended to wash it with to get it off without damaging the clearcoat?
Thanks in advance
Happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 09-07-2013, 03:29 PM   #2
"Cloudsplitter"
Thumbs up
A first class car was soap, (no dishwashing soap), and one of these.
Old 09-07-2013, 03:40 PM   #3
interstateflyer's Avatar
2017 25' International
Los Osos , California
So no Ivory or Dove dishwashing detergent?
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 09-07-2013, 03:44 PM   #4
"Cloudsplitter"
Wink
My 2 cents....I wouldn't use anything thats formulated to melt grease on china.
Old 09-07-2013, 04:11 PM   #5
1988 25' Excella
Washing the stream
Thank you all for the replys and I will get some good auto soap and go to work. Thanks arain.
Old 09-17-2013, 02:54 PM   #6
1984 31' International
1969 23' Safari
Flint , Michigan
If you take a look at most dish soaps they contain an oil (lanolin) ? of some sort to soften hands which will leave a film on the AS.... Car wash soaps do not
lundrunner is offline   Reply With Quote
Old 09-17-2013, 03:04 PM   #7
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
We look on the bottle and make sure the ingredients don't contain any ammonia or petroleum products. Apparently these two products are hard on the clear coat and are present in many dish soaps and car wash products. Armor All car wash liquid was once one of the safe products.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 09-17-2013, 03:53 PM   #8
1976 31' Sovereign
Oswego , Illinois
One of the washes I use is turtle wax & soap in one, does nice job leaves shiny plus gets rid of green algae which me have lots this year. Bill
Old 09-18-2013, 12:15 PM   #9
crabbey1's Avatar
1976 Argosy 22
Pasadena , California
Images: 33
Send a message via AIM to crabbey1 Send a message via Skype™ to crabbey1
I used Armor All and a brush on a pole that allows water to flow through the brush. I picked it up and Home Depot.
crabbey1 is offline   Reply With Quote
Old 09-18-2013, 02:50 PM   #10
"Cloudsplitter"
Some of the car wash brushes can scratch the clear on the newer trailers...
Microfiber mop on-a-pole has worked well for us...
Old 11-14-2013, 02:30 AM   #11
Smile Microfiber pad on a pole
I Finley found the magic waund for washing all the noks and cranes. While visiting Airstream NW in Oregon I saw them washing a rig with a Microfiber head on a wooden pole. I took a close look and knew I had found the magic waund. It's by Carrand and called "Microfiber Washglove" it's not really a glove but a pad with a strong elastic band around the opening to hold it onto the plastic base. Size is about 10 X 6" with a up and down mount with standard broom handle threading. AutoZone is where I got it. It is the ideal tool to wash the delliquite finish WITH!
Exscuse the spelling it's late at night.
Griff
Griff is offline   Reply With Quote
Old 12-01-2013, 06:56 PM   #12
mstephens's Avatar
2013 25' Flying Cloud
Cat City , California
I've had my 25FC for two years. I have tried all the usual "car washing" techniques with not much luck. Using the typical bucket, soap, mops and hoses, I found the following results: Soap left behind as runs and drips; dirt left behind in small places. LOTS of work trying to dry; spots on windows.
Then I discovered a different idea - dry washing. Well, not exactly dry, but close.
You need about four 16" x 16" cotton terry towels, a pail with clear water, some charcoal lighter fluid. No hose!
STEP 1. Make all four towels wet. Wring 2 of them until as close to dry as possible. The remaining 2 can be slightly wet, but not dripping.
STEP 2. Squirt a small amount of lighter fluid into the middle of the wet towel. This is the "washer." (The lighter fluid will loosen road films and grease spots. )
STEP 3. WIth the washer towel, wash a small section, say 3 feet wide, beginning at the top with a step stool. Turn the towel frequently. Rub stubborn dirt with the center of the towel that has lighter fluid.
STEP 4. Use the clean drying towel (slightly damp, never actually dry) to go over the area you just washed. ALL residues and streaks will come off, leaving a gleaming finish beneath with no streaks. It will dry without spotting in a minute or two.
STEP 6. REPEAT with each new section.
I find it takes much less time than conventional 'hose and soap' techniques and leaves a much clearer finish. I have tried various materials like "Sham-wow" and others. Nothing comes close to clean cotton terry towels. Not even close.
mstephens is offline   Reply With Quote
Old 12-01-2013, 07:51 PM   #13
Goal15's Avatar
Holly Lake Ranch , Texas
I use a similar technique but with Dawn dish soap, i figure if its good for rescuing ducks it can't be all bad. Just wash a section, rhen rinse and dry with rags made from old tshirts
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 12-02-2013, 04:53 PM   #14
2015 28' Flying Cloud
Melbourne Beach , Florida
Use Correct Detergent
Since the Airstream exterior is aircraft grade aluminum you do not want to use a cleaner with a pH above 10.0 or you may cause corrosion. If you use a highly alkaline or caustic product you can permanently ruin the finish. I use Penetone Corporation aircraft soap named Penair C5572. This is the same product used by the Navy to clean F-18's. Penair C5572 meets a military specification and will not corrode steel, aluminum, cadmium, or magnesium.
It is safe on all painted surfaces and will not degrade plastic windows.
Product is amazing. I have great cleaning performance and since product is almost neutral it is easy on the skin and eyes.
Kingsmen 33 is offline   Reply With Quote
Old 12-02-2013, 05:06 PM   #15
"Cloudsplitter"
Thumbs up
X2
Great for greased ducks...but if you seal or wax your AS the DW soap will remove it lickity split.
IMHO...a quality car wash soap is a much better option.
Old 12-02-2013, 07:21 PM   #16
Goal15's Avatar
Thanks Bob, good to know. I'll get some car soap for Thumpers spring bath to wash off the storage dust
Dana and Olga
2006 Safari 23
Old 04-08-2016, 09:26 AM   #17
Formerly FreshAir44
FOILED's Avatar
2008 23' Safari SE
Seattle , Washington
Thanks in advance
I also have green stuff along my seams and windows after winter storage. Small amounts still remain after washing with Maguire's car detergent. I don't want to damage my clear coat. Does anyone have experience using "30 Seconds Cleaner" to spray the AS and rinse?
FOILED is offline   Reply With Quote
Old 04-08-2016, 10:14 AM   #18
1976 31' Sovereign
Oswego , Illinois
I use turtle wax car wash and several other brands but only ones that have wax in formula, if nothing else works can mix small amount bleach in wash water, green gone. I see no damage to clear coat, only damage was washing in Fla. got some unseen sand on sponge.
Old 04-08-2016, 10:55 AM   #19
2016 27' International
Montreal , Quebec
Has anybody ever used a foam cannon like this.
http://www.chemicalguys.com/MTM_Cann..._p/eqp_304.htm
Papa smurf is offline   Reply With Quote
Old 04-08-2016, 03:04 PM   #20
2005 31' Classic
Pleasant Plains , Illinois
I might be deviating from the topic, but brushes leaving scratches in the clear coat was mentioned. Is there a cure for those scratches? They are only visible when the sunlight hits them and i'm standing and looking from a certain spot but are annoying to see. Will a good wax remove the scratches? They don't seem deep at all. That's my plan to try anyway. That and no more brushes no matter how soft they feel. Thanks for any ideas that are shared.
Greg
WGreg is offline   Reply With Quote
