Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 04-08-2003, 11:47 AM   #1
montanaandy
montanaandy's Avatar
Profile:
Walbernize - Which To Use
I have used the Walbernize Cleaner Polish & Glaze in the past (last spring/summer when I purchased the trailer 78-31' Intl) with what I would call "mixed" results (i.e. removed quite a bit of oxizidation but highlighted the AS pattern baldness). Now I see that the manuf. is not recommending the CPG for clearcoat finishes (use the RV Seal instead I guess). Is the CPG not to be used on newer trailers with the clearcoat fully intact and is it still safe to use on older trailers or should I switch to the RV Seal this pring when I clean the exterior of the trailer? Another somewhat related question - is my trailer a good candidate for clearcoat removal & polishing? Thanks, Montanaandy
montanaandy is offline   Reply With Quote
Old 04-08-2003, 03:03 PM   #2
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
I use the Walbernize RV superseal. They sell it also in gallon jugs if you call. If the finish is in poor shape, RV superseal won't do anything besides add a coat of protectant to the current finish. It does however, clean tree sap and other things off pretty well.
I can't answer the clearcoat question though.
Eric
Old 04-08-2003, 03:53 PM   #3
Melvin P. Thorpe
Profile:
RV Superseal for the new A/S's? and Armor All wash? What about the painted roof? I have heard that Walbernize will ruin the belly stipe.
SASS #41766
Melvin P. Thorpe is offline   Reply With Quote
Walbernize on Tow Vehicle? Pick Our Community 15 03-20-2004 12:13 PM
Walbernize cdholt Cleaning, Stripping & Polishing 1 10-19-2003 11:20 PM
Walbernize or ???? dscluchfc Cleaning, Stripping & Polishing 5 10-17-2003 01:45 PM
Walbernize UV protection Silvertwinkie Our Community 1 03-12-2003 03:40 PM
Walbernize...before and after pics Rog0525 Cleaning, Stripping & Polishing 1 09-16-2002 10:23 PM
