Old 07-30-2012, 08:52 AM   #1
1989 25' Excella
Albemarle , North Carolina
ugly sweaty Arms marks on polished airstream
While trying to retrieve my awning strap I put two sweathy arm marks on my airstream that has been polished aprx year and half ago. How do I get finish to resemble rest of trailer. (third airstream - 25 ft excella 1989 cira). Dont want to have a different color blog (dont want to redo whole trailer). I have always had trouble naviagating this forumn. Email address is marti2ray@vnet.net. Albemarle NC
eldin is offline   Reply With Quote
Old 07-30-2012, 09:21 AM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
If its just a sweetly arm mark try soap and water.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-30-2012, 09:27 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If he has not put a clearcoat over the freshly polished Aluminum, the sweat will eat into it and the mark will be permanent until he polishes it out again. Try just polishing out just the segment where the mark is and the differences from segment to segment might not be as noticeable.
Old 07-30-2012, 09:45 AM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Alcohol on a clean soft rag would be worth trying if the soap and water doesn't quite do it.
Vaughan
Old 07-30-2012, 10:29 AM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Been there...done that. None of those well intentioned suggestions will work. You will have to use a polish again in the area. It wont be bad. NuviteC followed by S will work, S alone probably won't. Truck box did not help me either. Maybe 3M Gravel in a bottle will...but I have not used it on small areas.
Never dull won't.
Old 07-30-2012, 11:17 AM   #6
casa3805's Avatar
Corpus Christi , Texas
Images: 41
Wow, if I have ever seem a post showing why a person should not polish, this might be it. Can't imagine what my trailer would look like with hand prints from 11 grandkids all down the side. Maybe a cave painting? (-:
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
casa3805 is offline   Reply With Quote
Old 07-30-2012, 12:22 PM   #7
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
As mentioned earlier, it may be a coating over the polished aluminum that is causing the issue.
I have a 5 year old, believe me, hand prints, jello, pudding, and all kinds of other things wash right off mine with soap and water.
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 07-30-2012, 01:29 PM   #8
1977 31' Sovereign
1989 34' Excella
The salt in the sweat is the problem if it is allowed to dry and concentrate on the trailer for a long period. Salt will eat into the polish if the trailer has not been clearcoated or at least has a good acrylic wax to protect it.
Old 08-01-2012, 05:26 PM   #9
Aluminum Addict
SeasideSteph's Avatar
1970 31' Sovereign
Rockport , Texas
I got super lucky and got both salt
and handprints!
I see lots of polishing in my future!
SeasideSteph is offline   Reply With Quote
Old 08-01-2012, 06:23 PM   #10
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
and handprints!
Lucky you! Lol!
1982 34' Limited
WBCCI #3321
TAC #GA-24
