Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 07-04-2002, 11:30 AM   #1
niftypkg
niftypkg's Avatar
Profile:  1971 27' Overlander
Cornville , Arizona
Wink Try this!!
Been taking out the windows and cleaning the Al.window frames with steel wool and polish. but the pitting and oxidation was tough to remove. Tried scraping it but left marks, soooo .I tried a bathroom tub and tile cleaner. The one I used was called eliminator from our good friends at HD. Applied it with the steel wool and it worked great --took the oxidation off!!! Just a teaspoon did it. Then polished with what ever!!!
niftypkg is offline   Reply With Quote
Old 08-22-2002, 11:02 AM   #2
Road Ruler
Road Ruler's Avatar
Profile:  1973 23' Safari
Burlington , South Western Ontario
Images: 41
Thumbs up Good Idea
Hello Nifty
I have the same stains on my 23 ft'r
What grad of steel wool did you find worked the best.
Thnxs in advance... Wayne
Old 08-23-2002, 06:49 AM   #3
niftypkg
niftypkg's Avatar
Cornville , Arizona
Unhappy Window frame Oxidation
Wayne, I used medium grade and it didn't leave scratches. The cleaner startes to form a black slurry when you rub and it stains. Wear gloves and You might want to use a protective wax after you clean.
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 11:49 AM
Oxidation removal on 63 Overlander jwi1939 Cleaning, Stripping & Polishing 0 03-04-2003 08:15 PM
Window Removal Rob Windows & Screens 2 08-31-2002 08:49 PM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 07:03 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 01:40 PM
