Old 06-03-2010, 04:30 PM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Touching up shiny finish
My trailer was highly polished a year and a half ago when I bought it. Since then I have kept it relatively shiny, except for one lower panel I completely clouded up messing with it.
My question is this, trying to maintain the high polish, I found using Cyclo and Nuvite S works best. But I still get very tiny black dots in pores and some streaks that are hard to get out.
I am using a cyclo and hand polishing. Wiping down with mineral spirits and all.
How do you with fairly shiny trailers maintain them?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 06-03-2010, 04:39 PM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
here are some shots I just took, maybe you can see the small black spots...
ID:	103927   Click image for larger version
AIR #005
retired!
Old 06-03-2010, 04:41 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
your on the right track
a Cyclo, Nuvite C and S (as required) micro fiber cloths and corn starch to get rid of the black...instead of the mineral spirits.
Old 06-03-2010, 07:00 PM   #4
airstreamjudy's Avatar
1968 24' Tradewind
Largo , Florida
Melody Ranch - thanks, I needed to know that also.
Judy
JudyW
airstreamjudy is offline   Reply With Quote
Old 06-04-2010, 09:34 AM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Dry cornstarch? You rub it on and off?
AIR #005
retired!
Old 06-04-2010, 11:29 AM   #6
1953 Flying Cloud
1953 Flying's Avatar
1953 21' Flying Cloud
West Sacramento , California
Images: 8
I also use the micro fiber towel and dry corn starch. I just dab the towel into a cup full of corn starch and then wipe it on and off. This should get rid of the black spots in the pores and around the rivet heads. I also think using mineral spirits take away the polishing from the Nuvite. Hope this helps
Custom driver license Pet ID's.
www.petidforme.com/105
1953 Flying is offline   Reply With Quote
Old 06-04-2010, 01:55 PM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
thanks a lot. I also used to have product called Purple Polish aluminum deoxidizer. I used it sucessfully on a classic Motorhome to cut off haze. Might try that on the tough spots.
AIR #005
retired!
Old 06-17-2010, 08:14 AM   #8
muddy_hollow's Avatar
1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
corn starch
Did you try the corn starch?
I've got the same problem...
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 06-17-2010, 08:56 AM   #9
JT
El Paso , Texas
corn starch
Thanks, the black is tuff to get off and I have tired everything, including mineral spirits, soap and water, buffing, and even Crud Buster which got it off but seemed to etch the metal - don't try it. If it works you will have made my day, week, month, etc.
jimbob79 is offline   Reply With Quote
Old 06-17-2010, 10:19 AM   #10
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I actually ordered a product I have used a long time ago on my Motorhome and previous trailer. Aluminum Deoxidizer from Cal Customs. Its a green liquid you wipe on then put a small amount of polish over it. It works well, there is almost no black residue to clean up.
I hope to get to use it on large areas soon, the spots I tried cleaned up quickly. It may be the ticket for what I need to do.
Will post the results.
AIR #005
retired!
Old 06-17-2010, 10:44 AM   #11
howco's Avatar
1970 27' Overlander
Sumner , Washington
You have created a monster..............a maintenance monster.......Ahhhhhhhhh
Favorite Bumper sticker:
Yes, this is my truck...
No, I won't help you move....
howco is offline   Reply With Quote
Old 06-18-2010, 03:52 PM   #12
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
It came to me a lot shinier than it is now However I feel obliged to keep it pretty while it is in my ownership.
AIR #005
retired!
Old 06-22-2010, 01:50 AM   #13
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
I've got the same problem. Looking forward to learning about your results with the Cal Customs product...
Good luck!
Art - W0ABX
High Desert Country of the Rockies
'85 Sovereign 25'er
WBCCI: 2197; AIR #: 36503; TAC #: NM-5
MaxAB is offline   Reply With Quote
Old 06-22-2010, 09:16 AM   #14
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I ordered the deox liquid, and on a small area it does seem to cut through the haze. I will have to wait a bit for cooler weather if we get any to really give it a try, the mid 90s are a bit much for polishing.
Shiny 1 shiny 1 Member Introductions 4 02-28-2007 05:58 PM
too shiny for the desert? nettepdx Furnaces, Heaters, Fireplaces & Air Conditioning 53 07-13-2005 10:39 PM
Keep The Shiny Side Up! ShinySideUp! Commercial Listings 0 05-25-2005 09:37 PM
Shiny Toybox Barry2952 Off Topic Forum 3 04-23-2005 08:07 AM
