Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 06-03-2010, 04:30 PM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Touching up shiny finish
My trailer was highly polished a year and a half ago when I bought it. Since then I have kept it relatively shiny, except for one lower panel I completely clouded up messing with it.
My question is this, trying to maintain the high polish, I found using Cyclo and Nuvite S works best. But I still get very tiny black dots in pores and some streaks that are hard to get out.
I am using a cyclo and hand polishing. Wiping down with mineral spirits and all.
How do you with fairly shiny trailers maintain them?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 06-03-2010, 04:39 PM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
here are some shots I just took, maybe you can see the small black spots...
ID:	103927   Click image for larger version
AIR #005
retired!
Old 06-03-2010, 04:41 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
your on the right track
a Cyclo, Nuvite C and S (as required) micro fiber cloths and corn starch to get rid of the black...instead of the mineral spirits.
Old 06-03-2010, 07:00 PM   #4
airstreamjudy's Avatar
1968 24' Tradewind
Largo , Florida
Melody Ranch - thanks, I needed to know that also.
Judy
JudyW
airstreamjudy is offline   Reply With Quote
Old 06-04-2010, 09:34 AM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Dry cornstarch? You rub it on and off?
AIR #005
retired!
Old 06-04-2010, 11:29 AM   #6
1953 Flying Cloud
1953 Flying's Avatar
1953 21' Flying Cloud
West Sacramento , California
Images: 8
I also use the micro fiber towel and dry corn starch. I just dab the towel into a cup full of corn starch and then wipe it on and off. This should get rid of the black spots in the pores and around the rivet heads. I also think using mineral spirits take away the polishing from the Nuvite. Hope this helps
Custom driver license Pet ID's.
www.petidforme.com/105
1953 Flying is offline   Reply With Quote
Old 06-04-2010, 01:55 PM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
thanks a lot. I also used to have product called Purple Polish aluminum deoxidizer. I used it sucessfully on a classic Motorhome to cut off haze. Might try that on the tough spots.
AIR #005
retired!
Old 06-17-2010, 08:14 AM   #8
muddy_hollow's Avatar
1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
corn starch
Did you try the corn starch?
I've got the same problem...
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 06-17-2010, 08:56 AM   #9
JT
El Paso , Texas
corn starch
Thanks, the black is tuff to get off and I have tired everything, including mineral spirits, soap and water, buffing, and even Crud Buster which got it off but seemed to etch the metal - don't try it. If it works you will have made my day, week, month, etc.
jimbob79 is offline   Reply With Quote
Old 06-17-2010, 10:19 AM   #10
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I actually ordered a product I have used a long time ago on my Motorhome and previous trailer. Aluminum Deoxidizer from Cal Customs. Its a green liquid you wipe on then put a small amount of polish over it. It works well, there is almost no black residue to clean up.
I hope to get to use it on large areas soon, the spots I tried cleaned up quickly. It may be the ticket for what I need to do.
Will post the results.
AIR #005
retired!
Old 06-17-2010, 10:44 AM   #11
howco's Avatar
1970 27' Overlander
Sumner , Washington
You have created a monster..............a maintenance monster.......Ahhhhhhhhh
Favorite Bumper sticker:
Yes, this is my truck...
No, I won't help you move....
howco is offline   Reply With Quote
Old 06-18-2010, 03:52 PM   #12
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
It came to me a lot shinier than it is now However I feel obliged to keep it pretty while it is in my ownership.
AIR #005
retired!
Old 06-22-2010, 01:50 AM   #13
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
I've got the same problem. Looking forward to learning about your results with the Cal Customs product...
Good luck!
Art - W0ABX
High Desert Country of the Rockies
'85 Sovereign 25'er
WBCCI: 2197; AIR #: 36503; TAC #: NM-5
MaxAB is offline   Reply With Quote
Old 06-22-2010, 09:16 AM   #14
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I ordered the deox liquid, and on a small area it does seem to cut through the haze. I will have to wait a bit for cooler weather if we get any to really give it a try, the mid 90s are a bit much for polishing.
Old 06-23-2010, 03:05 PM   #15
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
A company that makes an aluminum spray cleaner/dexodizer is letting me try their product to review. As soon as I get it i will check it out and give you all the scoop.
Old 06-23-2010, 03:55 PM   #16
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Application
Alan...I talked with customer service at cal custom today regarding the aluminum deoxidizer and polish. But absently forgot to ask about he application. Didn't find anything on their website. Is the polish put on with buffer or by hand? By the way, their customer service department went out of their way to send a sample. Will be anxious to give it a try. Our "78" has not been polished but the clearcoat has been removed. Wouldn't it be great to have a product that you just spray/wipe on and bingo...shiny trailer. Wishful thinking.
Roadrunner is offline   Reply With Quote
Old 06-23-2010, 05:40 PM   #17
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
you apply the deoxidizer with a cloth soaked in it, do not let it dry or wipe it off, then you apply the purple polish immediately after. Please,let us know what you think about this product. It did a great job on my freshly strippped Classic motorhome a few years ago.
Not mirror shiny but very nice.
Old 06-23-2010, 05:42 PM   #18
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I am assuming the spray aluminum cleaner will help with an oxidized already polished finish, at least I hope so. I have used automotive windshield cleaner to help shine it some and that works somewhat.
Shiny 1 shiny 1 Member Introductions 4 02-28-2007 05:58 PM
too shiny for the desert? nettepdx Furnaces, Heaters, Fireplaces & Air Conditioning 53 07-13-2005 10:39 PM
Keep The Shiny Side Up! ShinySideUp! Commercial Listings 0 05-25-2005 09:37 PM
Shiny Toybox Barry2952 Off Topic Forum 3 04-23-2005 08:07 AM
