Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 03-06-2006, 10:21 PM   #1
72Blazerod
72Blazerod's Avatar
Profile:  Delta , British Columbia
Images: 31
Too cold to polish?
Hi guys,
I am just wondering if it is too cold to polish my trailer on a clear, crisp day that is only about 40* F (about 4*C)? I know that it can be too hot to polish and the polish dries too fast, but can it be too cold? I have a two week holiday starting next week and would love to get the trailer polished BEFORE the summer (so I can change my Avatar picture to a nice shiny trailer). Any comments are welcome.
Rod
72Blazerod is offline   Reply With Quote
Old 03-07-2006, 04:00 AM   #2
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Originally Posted by 72Blazerod
Hi guys,
Rod
I have polished my rig at or about 45 degrees F. So I'd give it a try! Isn't it always a good time to polish!!!
'74 Overlander (Rear Bed)
'77 20' Argosy MH (Looking for a new home)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281 w)
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 03-07-2006, 04:02 AM   #3
53flyingcloud
53flyingcloud's Avatar
Profile:  Amherst , New Hampshire
Greetings Rod~
YES, it can be too cold to polish properly. You didn't say which type or make of polish compound that you had but, Nuvite says that the outside temp should be above the 60 degrees range before using it's product.
Several years ago, I tried to strech my polishing efforts into the month of Oct and, found first hand, when its cold out..you might as well give it up..The polishing compound doesn't work..It had gotten down to frost~!
Think Spring..it's only a few weeks away...
ciao
53FC
53flyingcloud is offline   Reply With Quote
Old 03-07-2006, 07:18 AM   #4
airstream4
airstream4's Avatar
Profile:  1997 34' Limited
1963 22' Safari
Troy , Michigan
I have polished two Airstreams learning all the way. I found 55-70 was ideal temperature in Michigan. It seemed that below 55 didn't work. This was in the spring last year. My first polish job was done in 70-85 weather in late summer you could tell differance as temperature rose.(or was that just me?) In the shade is definately preferred!
Paul
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
Old polishers take note Bradjun1 Cleaning, Stripping & Polishing 3 06-08-2005 04:06 AM
cold weather how do air streams do? overlander Our Community 2 10-02-2002 05:10 AM
polish a brushed trailer? john hd Cleaning, Stripping & Polishing 6 08-25-2002 10:03 PM
Best Polish to restore Airstream ?? bgow 1969 Overlander 1 08-06-2002 10:23 PM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
