Old 09-08-2007, 03:39 AM   #1
Petethefeet's Avatar
1964 30' Sovereign
1959 22' Flying Cloud
1957 26' Overlander
Raglan , New Zealand
Images: 14
Smile To polish or replace?
Hi, the attached pics show my 64 Sovereign, I have been compounding with F9 to date and am nearing the point where I will be working on the topmost panel which runs the full length of the trailer. Ultimately, there will be an aircon. unit, and solar panels on top, along with the replacement roof vents. What I am wondering is whether or not it would be a more economical exercise to replace the entire top panel as opposed to polishing the corrosion out. There would be well over 300 rivets to replace in addition to the panel itself. It is not visible from ground level, and would be even less so once the accessories are fitted. Has anyone traded these options off against each other with a result? Thanks for any help.
Pete.
Help fight obesity, try polishing an Airstream!
ID:	44592   Click image for larger version
ID:	44594   Click image for larger version
Petethefeet is offline   Reply With Quote
Old 09-08-2007, 06:15 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hello Pete -- It's quite amazing taking this feat on in New Zealand. More power to you!
Another thing to consider is the current practice of painting the top panel white. White reflects more of the spectrum and absorbs less heat. Members here have done this to older units. Although mine has it I can't tell you the last time I saw it -- nobody can tell if done properly. I don't know if you can see any of this corroded panel if you stand off to the side. A painted top would be easier to maintain with the various items penetrating the roof.
Threads on the subject -- there are more but you get the picture:
http://www.airforums.com/forums/f4/d...reign-422.html
http://www.airforums.com/forums/f48/white-top-4962.html
http://www.airforums.com/forums/f4/w...oof-17047.html
http://www.airforums.com/forums/f4/o...eam-18988.html
http://www.airforums.com/forums/f4/c...oof-11847.html
http://www.airforums.com/forums/f381...ting-1131.html
http://www.airforums.com/forums/f4/c...ream-5721.html
http://www.airforums.com/forums/f4/p...ofs-14823.html
http://www.airforums.com/forums/f142...ofs-11058.html
http://www.airforums.com/forums/f4/w...oof-11706.html
5 meter Langford Nahanni
Old 09-08-2007, 06:47 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If you decide to go the white route, Kool-Seal makes white "elastometic roof coating" you can apply with a roller. It helps keep the trailer cool, will fill in the spots of corrosion, and deadens sound of rain on the roof. (the last part is important to me, we get rain here that sounds like God has ordered up another 40 day monsoon).
Old 09-08-2007, 08:33 AM   #4
Aside from the large scale of this task -- if you are reasonably weather-tight I would try to avoid replacing the panel. Getting this all sealed again without leaks (okay, they all leak) -- without more leaks ... you know what I mean.
Old 09-08-2007, 08:36 AM   #5
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Pete.
Pete,
I was (am still) struggling with the same issue. My roof panel is almost as bad as yours.
The sides up to this panel came out great, but the actual roof panel is an eyesore when viewed from straight above, and close up....which brings me to the realization that it really does not matter much, appearance wise.
But just knowing it's up there und ugly bothers me enough to where I have included it in the "things to still do" list. I have decided to paint it white. Only I think I am going to use automotive paint and aluminum primer, instead of the elastomeric material. I have seen this material age on the white trailers, and it seems to age into a greyish yellow with a streaky appearance.
My trailer got pounded by Texas summer rains during a trip in July, relentless for almost 2 weeks. I discovered some leaks around the roof vents. Despite the fact that I double and triple sealed everything with the recommended materials. Now I am glad the panel isn't painted yet. I will have to work on it and remove roof vents to reseal etc. My point is that you might want to make double sure that your roof is waterproof, before investing work into the panel that has all the holes for vents etc.
Uwe
www.area63productions.com
Old 09-08-2007, 01:01 PM   #6
1964 30' Sovereign
1957 26' Overlander
Images: 14
Thankyou all for your response and helpful and constructive advice. The painting option is starting to sound rather appealling. Preparation-wise (for the paint) would the corrosion have to be removed anyway? Any etching coat? As for the waterproofing, the inside is completely gutted to the frame, I am planning on resealing everything from the inside as per existing, it sounds as though it may not be enough. I would really like to be able to have a waterproof trailer, especially in the condition it has been stripped back to, it seems like an opportunity to correct any design faults, any other ideas or points to look out for regarding waterproofing the shell?
Pete
Old 09-08-2007, 02:19 PM   #7
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Pete
Hello Pete,
Keep in mind that your trailer is 45yrs old, and that it is very long. It has flexed and twisted for many years, being towed down the road. It might have been abused or stored improperly, who knows.
To reallt get this waterproofed, you will have to do a fair amount of investigating,a nd remove ll the window rames etc in order to be successful. Merely seaming all the seals from the inside does not guarantee a drip free environment. Ask me how I know...been there, done that, am getting dripped on. In my case it seems to be the 3 roof vent openings that cause the trouble, and the front window frame. I must have missed a microscopin spot on teh front window, and how on earth the vents can leak, I don't know. I used gobs of sealant, and made sure everything was level and clean. Well, now I get to do it again. The large rectangular front vent is the worst offender. Might be the only one, and the water might travel to the fantastic vents and drip down. I will have to reseal all three, though, to be sure. The front window should be easy, i will seal it better from the outside without removing it. But to be sure, you might consider removing the windows, or at the very least resealing them all very carefully, while the inner skin is off. Also the lower rivet line where it meets the belly pan. Take a very close look at that and seal it as much as you can from the inside. I used a brushable seam sealer formulated for aluminum, from auto body shop supply.
Uwe
Old 09-08-2007, 05:28 PM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Kool-Seal, Is it really?
Can anybody out there testify that this stuff makes any noticible difference in keeping an Airstream cooler in the summer sun?
Old 09-08-2007, 05:32 PM   #9
Well Preserved
1993 21' Sovereign
Yes. It was a marked improvement on our Argosy,We used it one weekend without the stuff, and the following weekend with the stuff, weekend #2 was about 5 degrees cooler inside. Both weekends hot and sunny. It should make a bigger difference when painting white where it used to be silver.
Old 09-08-2007, 05:35 PM   #10
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Therre is a comparison test somewhere in the belly of the forums, done by InlandRV,I believe, on which paint color stays coolest. Relentless searching might reveal this test.
Uwe
Old 09-08-2007, 05:40 PM   #11
1964 30' Sovereign
1957 26' Overlander
Images: 14
Yikes, now I'm really worried, well, concerned enough to have a coffee and a bit of a ponder at least. I thought replacing the vents anew might have bypassed any problems around that area, but clearly, even with due diligence, it sounds as though I will have to be extra careful. There are some obvious sites for leaks around the bottom of the windows that I can see will need attention. I find it hard to believe that it was never expected to leak at all with that sort of method of construction, the way the laps of some of the sheets are running. Did they ever not leak? I guess all I can do is take all your helpful advice and do my best and test it with a high pressure water blaster before lining the interior. Phew! what a mission!
Pete
Old 09-08-2007, 06:10 PM   #12
Well Preserved
1993 21' Sovereign
If you use the Kool-Seal, I didn't do anything but make sure the surface was clean and dry. If you are going to use regular (automotive-type) paint, the aluminum will need to be prepped. Where the area you are considering treating is located, I would not worry about filling in area of corrosion, unless there are holes in the roof. It doesn't look like there are from your photos.
Old 09-08-2007, 06:25 PM   #13
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Pete
I am not sure if high pressure is necessary. High volume rain was more like when I experienced the leaks. Lots of water or less standing on the roof panel and running down the sides.
High pressure/low volume might not work too well for this purpose. I have never seen a leak when I take the trailer to a coin car wash with the high pressure hose.
Uwe
How much polish do I need? sigv Cleaning, Stripping & Polishing 19 07-22-2008 07:32 PM
to polish or not to polish that is the question Frank's Trailer Works Cleaning, Stripping & Polishing 17 08-26-2007 11:15 AM
Need Help with Polish rebel beck Cleaning, Stripping & Polishing 5 06-13-2007 03:40 PM
To Polish or not to Polish, that is the Question? mello mike Cleaning, Stripping & Polishing 14 03-22-2005 11:28 AM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
