Old 04-04-2016, 08:35 AM   #1
1972 25' Tradewind
Walker , Michigan
Tips on which polish to start with
Our 72 Tradewind 25ft AS had been polished before by previous owners. It's due again now that it's finished on the interior. Any suggests on where to start polishing grade? Should I just go for the S compound? Or does it need more? Also, any recommendation on a polished that won't break the bank? Here's it's current state.
And since we love pictures, a few interior pictures!
Complete Overhaul/Resto'd 1972 Airstream TradeWind Land Yacht 25'
TV= 2002 Jeep Grand Cherokee 4x4 4.7L V8 128k miles
Docster is offline   Reply With Quote
Old 04-04-2016, 09:19 AM   #2
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Nice Airstream ! I would use Nuvite S with cyclo -- unless you are looking for a show piece - and you should be good to go !
Ken J
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 04-04-2016, 09:47 AM   #3
1972 25' Tradewind
Walker , Michigan
Not looking for a show piece. Just want to maintain/improve a bit. What's a cyclo? Also, any recommendation on a wax for afterward to help protect it and make it last longer?
Old 04-04-2016, 11:07 AM   #4
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Cyclo = www.cyclotoolmakers.com/polishers.php
Sirs Gawain & Galahad
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 04-04-2016, 11:07 AM   #5
Ken J's Avatar
Durango , Colorado
Images: 14
A cyclo is a electric polisher with two heads - a must for polishing these trailers - Nuvite S has a wax mixed in so no need to wax it - however - should probably polish once per year - especially if you keep the trailer outside.
Do a google for "cyclo polisher" and you will see what it is - think I got mine at a company called Perfect Polish - should come up in a google search as well - its where I buy my Nuvite polish.
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 04-04-2016, 11:13 AM   #6
1972 25' Tradewind
Walker , Michigan
Ken J.
Perfect. Thank you. That is very helpful. Just ordered one!
Old 04-04-2016, 11:23 AM   #7
1972 25' Tradewind
Walker , Michigan
Just tried to order one. No go, out of stock at autogeek where I had a 20%off. Any sites have discounts on them ever?
Old 04-04-2016, 02:34 PM   #8
1972 25' Tradewind
Walker , Michigan
Also, do I get the variable speed or fixed speed model?
Old 04-04-2016, 07:32 PM   #9
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi Docster. A Cyclo polisher can be order from the factory, or Perfect Polish, or Vintage Trailer Supply, or maybe even Amazon. I have a single speed one that has lasted many years and works great.
I just did a 'maintenance" polish on my Trade Wind. I like the Nuvite F7 with my cyclo, and then I do another round with the Nuvite S with the Cyclo. Nuvite S is more of a sealer. It struggles to remove a water spot. The F7 is more aggressive. I use the fleece wrap around the Cyclo.
Visit the Perfect Polish website. There they have detailed instructions for polishing aluminum. It was helpful to me.
David
Old 04-04-2016, 07:52 PM   #10
1972 25' Tradewind
Walker , Michigan
David
Good info. I have the water spots as well. So 1 pass with F7, then finish up with S sounds like the plan for me. How fast or slow should I be moving?
Old 04-05-2016, 11:55 AM   #11
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Docster
Very nice work on your interior renovation. What are the specs and where did you get the aluminum you used for the interior walls?
Thanks, Dan
Old 04-05-2016, 12:10 PM   #12
Ken J's Avatar
Durango , Colorado
Images: 14
Polishing is a Zen experience - you don't want to rush it - maybe the most 18"x18" at a time - use the polish sparingly - a dab will do it on the cyclo head - size of an M&M is about right - put the dab on the head - move it around on the trailer in a small section with motor off - then let the machine do its job - if you order fleese from Perfect Polish - I would also order some micro fiber towels to wipe off the small amount of residue with corn starch - On the F7 - if you need it use it - however the standard advice is to start with the highest grade - in this case the S - if you are satisfied with the results you are good to go - you can always use a more aggressive polish if your not satisified. - no need to make more work than you need to
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 04-05-2016, 06:38 PM   #13
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Ken J gives good advice. My water spots would not disappear with S, so I had to start with F7. Actually F7 and the Cyclo leaves a pretty good finish, but a follow up with the S makes it even better.
Use only a small amount of polish for the area you are working. I use just one finger dab, and then "finger print" it on the area I'm working. Then I smear it around with the Cyclo running. The polish will develop a gray "polish bed" as it dissolves. Then keep polishing until all the gray is gone. If you get a dark gray or black polish bed, you have used too much polish. Too much polish is really a waste of time as the carrier tends to lubricate the skin the the abrasive doesn't get a chance to scratch away on the skin very well.
You just have to jump in and try it. It takes some time to develop the technique that gives you the results you want. It's kinda fun for the first hour or so. But after that, not so much.
David
PS Touring Dan, I buy aluminum sheet and rolls from Airparts in Kansas City. They are a supplier to the experimental aircraft crowd. I have found their service very good. Find them on the internet. I would think belly pan material 5052 at .025 thick would make a good decorative panel for the interior. It is easy material to work with and it has a nice finish, not milled or brushed. I'm on my third belly pan replacement project using Airparts 5052.
Old 04-13-2016, 09:13 AM   #14
1975 31' Sovereign
Prudenville , Michigan
Love the inside. I might steal your floor idea. Have no clue about polish but I like how shiny it is now.
Hamptastic75 is offline   Reply With Quote
Strip 'n Polish Project Thread (lots of great tips and links) Ferroequine Cleaning, Stripping & Polishing 422 03-11-2018 08:46 PM
My RV will start using the Aux Start but not with the chassis battery mcm9970 Land Yacht/Legacy Motorhomes 7 05-19-2013 07:47 PM
to polish or not to polish that is the question Frank's Trailer Works Cleaning, Stripping & Polishing 17 08-26-2007 11:15 AM
To Polish or not to Polish, that is the Question? mello mike Cleaning, Stripping & Polishing 14 03-22-2005 11:28 AM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
