07-10-2016, 08:52 PM
#21
2012 23' FB International
Woodstock
, Ontario
Originally Posted by prairieschooner
The crazy thing is I can still get Lacquer Thinner & Acetone, who'd a thunk!
That's really scary. Both those things are really health hazardous. Varsol is basically a light grade of petroleum distillates ( i.e diesel/furnace oil without the smelly stuff). Esso originally made it to substitute for the really flammable nature of Turpentine. It has the same 'flash point' as diesel fuel.
Here in Ontario we cannot purchase concentrated Round-up or any form of 2-4D weed killer, or anything strong enough to treat bugs in the lawn. So we all go to Michigan and stock up on the good stuff. My move on being denied Varsol would be to go to the nearest state and buy enough to last a year or two.
JCW
07-10-2016, 08:59 PM
#22
Woodstock
, Ontario
Originally Posted by Alumineer
Methanol is used as the base component for model airplane engine fuel, it's available mixed with gasoline in ratios up to 85% for use in car engines (with suitable adaptation for the fuel flow rate required, and the corrosiveness of methanol) and it's also the primary constituent of windshield washer fluid as an antifreeze. In Canada, windshield washer fluid usually has enough methanol to be rated to -40F / -40C.
I use to make windshield washer fluid in our chemical plant. The best stuff actually uses Isopropyl Alcohol. Methanol tends to smear and leave a film of water that freezes on the window glass. There is a balance between the two alcohols for cheaper grades. Neither form of alcohol will do the same as Varsol or paint thinner.
JCW
07-10-2016, 09:01 PM
#23
Hollis
, New Hampshire
07-10-2016, 10:28 PM
#24
1980 24' Caravelle
vallejo
they're at it again
Welcome to the people's republic of california, the state where you can't do a bleep thing. Still stuck here for forseable future.
07-11-2016, 12:25 AM
#25
2007 22' International CCD
Corona
They Are At It Again!
Sympathy. I do understand.
We won't talk about antenna restrictions, either.
That's why primary Shack is the AS.
And I have a very nice flagpole grounded to the back fence that works equally badly in all directions. 😀😀
KE4GNK.
07-11-2016, 07:31 AM
#26
1958 18' "Footer"
Idyllwild
Originally Posted by cazual6
Don't kill me for asking. Why do you need it? And what do you do with it?
I am polishing my '58 Traveler and I have been using mineral spirits to clean between polishing grades. I don't want to use anything more harsh that may degrade any sealants in place.
I sometimes do varnish work (but not for my Traveler) and have always used mineral spirits to clean my brushes, I have some brushes that are decades old. These were expensive back then and are "old friends" ...after I clean them I work some motor oil into the bristles to keep them from drying out, then wrap them in aluminum foil to help them keep their shape and then seal them in a baggie before putting them into the freezer. When needed I let them thaw & then clean again with mineral spirits.
WD 40 works well for most things but I Want My Mineral Spirits!
07-11-2016, 08:29 AM
#27
Overland Adventurer
2009 34' Panamerica
Telluride
Havent things gotten so tough in California thay have also banned water?
07-11-2016, 08:47 AM
#28
2013 27' FB International
2012 23' Flying Cloud
GVA
, British Columbia
Back in the day turpentine was the solvent of choice before paint thinners . Go to a Art Supply store , they probably sell by the liter or Quart.
Laurence
07-11-2016, 09:23 AM
#29
El Dorado Hills
Looking on the Internet mineral spirits are not banned in California. Home Depot still offers it. What's probably different is the formulation. Appears to be a low VOC product.
07-11-2016, 09:44 AM
#30
Master of Universe
2008 25' Safari FB SE
Grand Junction
You're thinking of methane, which is the primary constituent of natural gas.
Methanol is the alcoholized form of methane, and it is a liquid at room temperature. It's also called "methyl alcohol" and the water-diluted form is called "methyl hydrate", which is commonly available in home improvement stores.
I knew something seemed wrong when I was doing the post, but I didn't follow up my suspicion. Thanks for the correction.
I've seen -40˚ windshield washer fluid in Colorado, but more often lately it is -20˚. That may be because I moved to a warmer part of the state. Having experienced -40˚, I'm glad I'm not a windshield in the mountains.
Does methanol evaporate as quickly as rubbing alcohol? I remember people using some form of alcohol in their radiators—that was in the 1950's. After one season, it was too weak to work again. If methanol does evaporate fairly quickly, I guess windshield washer has a shelf life issue in the container and in the vehicle.
Gene
Gene
07-12-2016, 12:38 AM
#31
Stay CazuaL
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda
wow! I am not there yet. I just ordered the Cleaner/Wax as stated in the manual. Thanks for the info.
07-12-2016, 08:32 AM
#32
1958 18' "Footer"
Idyllwild
This is not the mineral spirits of yesteryear.
