Old 04-02-2015, 03:43 PM   #1
1962 19' Globetrotter
Vancouver , British Columbia
These deep deep scratches..
So my cutting is going alright, a lot of deep pits but what do you do...
My question is the scratches... I have some deep ones. I've been using 400grit on an orbital to help with how bad the skin is, wondering how hard some of you have gone with the sand paper?
I'm thinking on these to start with 200-250 work up to 600 and cut from there? I won't get it perfect this year but I'm hoping my black to red to white on the bars will do until I get a cyclo this winter. And if anyone has had success with the white as a final type of polish let me know how good it came out!
Name:	ImageUploadedByAirstream Forums1428010858.419602.jpg
ID:	235464Click image for larger version
Name:	ImageUploadedByAirstream Forums1428010874.179293.jpg
ID:	235465Click image for larger version
Name:	ImageUploadedByAirstream Forums1428010890.515496.jpg
ID:	235466Click image for larger version
Name:	ImageUploadedByAirstream Forums1428010904.732918.jpg
ID:	235467Click image for larger version
Name:	ImageUploadedByAirstream Forums1428010933.033929.jpg
Stupidnoob is offline   Reply With Quote
Old 04-02-2015, 04:11 PM   #2
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Don't use anything more coarse than 400! I would also wet sand by hand. An orbital sander will remove material very quickly! The scratches will prob never go away, but you can minimize them especially after using mineral spirits after polishing.
Cochese is offline   Reply With Quote
Old 04-02-2015, 04:58 PM   #3
I agree I don't think they will never go away just want to minimize as much as I can
You think 250-300 is too harsh?
Old 04-02-2015, 08:19 PM   #4
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Absolutely ! Aluminum is very soft
Old 04-02-2015, 10:36 PM   #5
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
They say that the skin has a brass core...is this true?
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 04-02-2015, 11:28 PM   #6
2007 22' International CCD
Nope. It's aluminum through and through. Brass is too expensive.....
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 04-03-2015, 07:40 AM   #7
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
I see the front window is covered with an aluminum sheet. Wow.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 04-03-2015, 08:12 AM   #8
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
I have a few beauty marks on mine too. The best you can do is average them out. You will have some very nice and very shiny scratches. You could always take up engraving and turn it into something.....
NavyCorpsman is offline   Reply With Quote
Old 04-03-2015, 09:04 AM   #9
Name:	ImageUploadedByAirstream Forums1428073281.449874.jpg
Mines not your avg streamer lol, I'm trying to get it as nice as I can.... But the previous po's when I got the destroyed gutted shell had done some crazy bad work, like BAD.
It's taken me three years to get to here. I don't mind sanding but this is all trial and error and I want to be efficient. Was thinking about starting at 300 to 400 to 600 then wet sanding it out from there then cut it with my bars I've been using??!?
Old 04-13-2015, 08:05 PM   #10
Name:	ImageUploadedByAirstream Forums1428976904.429224.jpg
ID:	236241Click image for larger version
Name:	ImageUploadedByAirstream Forums1428976925.693109.jpg
ID:	236242Click image for larger version
Name:	ImageUploadedByAirstream Forums1428976943.263559.jpg
Mine has been one of the worst skins I've seen on here
Roofing compound smeared everywhere, sticky caulking smeared everywhere, I mean everywhere.
I've managed to find a good system for me I'll share with you.
I start with 400 on an orbitAl, move to 600, wet sand 800 then to 1000.
Then after that, I use the black emery bar to cut. Has worked very well for the amount of **** kicking this poor girl took on the outside.
Have not come close to going through alcad. It's tougher then you think!!!!
Old 04-19-2015, 02:07 PM   #11
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Thanks for posting this, I have a lot of scratches on mine too and am just curious to see what other's have done. As for the skin, I believe it's two layers, something like a harder very thin outer layer and a softer inner aluminum layer. Different aluminum compositions were used at different times.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 04-22-2015, 05:07 PM   #12
No problem!
My skin was sooooooo buggered.
This has gone well so far, although deep scratches and pits will always remain, what a difference
Old 04-24-2015, 07:02 PM   #13
Name:	ImageUploadedByAirstream Forums1429923640.636436.jpg
Name:	ImageUploadedByAirstream Forums1429923668.767032.jpg
Name:	ImageUploadedByAirstream Forums1429923684.161095.jpg
Name:	ImageUploadedByAirstream Forums1429923703.013054.jpg
Starting on the roof, same method. Working well.
Old 04-25-2015, 07:25 AM   #14
1964 24' Tradewind
Lawrence , Kansas
I think we sometimes get too obsessed with trying to make old things look new. I like well cared for old things (like my wife). I say say shine her and do not worry too much for a few character wounds. They are part of what makes bringing new life to an old thing rewarding. Sort of an ode to it's past.
ttbikes is offline   Reply With Quote
light clear coat scratches LBC Safari Clearcoat, Exterior Paint & Trim 4 12-17-2016 08:39 PM
Deep scratches in clear coat. 2009 Flying Cloud Lucky Tom Clearcoat, Exterior Paint & Trim 11 02-10-2016 05:20 AM
Repairable deep scratches ghaynes755 Ribs, Skins & Rivets 4 05-15-2014 09:46 AM
scratches,lightning and other issues strayhorse General Repair Forum 8 12-28-2008 03:19 PM
how to remove scratches from clearcoat qqq Clearcoat, Exterior Paint & Trim 0 08-21-2003 06:37 PM
