Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 05-06-2004, 08:30 AM   #15
JPAIRSTREAM
JPAIRSTREAM's Avatar
Profile:  1972 31' Sovereign
, Ohio
Images: 47
I did start using a Makita variable speed buffer with a 2-sided 3m pad. The compound I was using was the famous Southern Shine. Southern shine does work. However, it was not bringing me to the shine I wanted. So I switched to using the Cyclo and Met-All using a wool pad. When I went back to clean up and remove swirl marks I used Blue Magic polish and a Foam pad. Keep in mind my surface was already shiny but was swirled after using the Met-All. The last process took all of this out and fine scratches.
The biggest thing I learned was to complete an area before going to the next, start at the top, and work your way down. This is a very dirty process and things tend to fall down and get on the lower panels. So, if these panels are complete they are being splashed with compound. Unless you are to mask them off as you’re completed.
My trailer will be getting coated and the lower painted pewter gray along with all the red, white, and blue trims.
My trailer is far from being perfect however, it looks pretty good to me.
Thank you for the kind words.
JP
JPAIRSTREAM is offline   Reply With Quote
Old 05-06-2004, 08:56 AM   #16
tin can luv
tin can luv's Avatar
Profile:  1968 22' Safari
1976 27' Overlander
Newport , Washington
Images: 82
If I may interject my opinion
After playing around last night, I passed over the surface at least eight times trying to get rid of the corosion. I pulled the cyclo out of the box, and gave it a whirl. It cleared up those swirl marks almost instaintly. Here's a couple of pics. I only cyclo'ed the upper area, you can still see the swirls on the bottom half.
I would say the cyclo is a must.
I do think that I may need to order a higher rated polish to get out the corosion, I tried everything and had no luck.
JP, that is a great pic, behind the truck. You should be proud!!!!!
ROn
Ron ... now in Newport, Washington
[font=Impact][font=Arial Black]
tin can luv is offline   Reply With Quote
Old 05-06-2004, 03:35 PM   #17
JPAIRSTREAM
, Ohio
Images: 47
Thank you... I am very proud of the job I have accomplished. But also tired
JP
Old 05-06-2004, 03:53 PM   #18
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
JPAIRSTREAM
You deserve to be proud of that polish job.
Granted, your tired, but just think, you can now sit in that picnic chair, facing the trailer, with a cold beer in your hand, and see the reflection of the guy who did that, along with his "BIG" smile.
Any job well done, is worth doing.
Makes a person proud. Tired, but proud.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 05-06-2004, 04:54 PM   #19
JPAIRSTREAM
, Ohio
Images: 47
Thanks Andy...
The sad thing is there is no turning back after you start. I think that anyone that has little patience need to not even attempt this. becasue about 30 hours in they will think there getting nowhere. truth is it seems like you will never finish. I actually went over the side seen in picture another 8-10 hours after that. not counting going over front and rear end.
Polishing is not all its cracked up to be.. rewarding yes but fun not really
JP
Old 05-06-2004, 05:27 PM   #20
53flyingcloud
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
1964 19' Globetrotter
1953 21' Flying Cloud
Amherst , New Hampshire
And, you said:My trailer is far from being perfect however, it looks pretty good to me.
JP,
Very Nice work`!!
I bet you felt the shoulder muscles, after 30 hrs, tighten up~!
That's really what it's all about~!
Ron,
If you wanta try something kewl..go out at night with a blue LED light and, shine it on that side of your unit~! (let us know what you think)
ciao
53FC
AIR 807
53flyingcloud is offline   Reply With Quote
Old 05-06-2004, 05:33 PM   #21
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
Wink You better be serious before you start....
I totally agree. Polishing is a big investment in time and labor not to mention the money.
After around 50 hours and your half way done your wondering if you ever will get done.
I have about 90 hours into mine and have NOT gone over it with the cyclo yet
But it looks better and better to me as I think about all the work it would take to keep going over it. You can always polish a little more.... You just have to decide when enough is enough.
Also, don't forget to add in the price for new carpet for your house when you have been tracking in black residue over it for a few months!
It is rewarding though when your done. I would do mine again. Not sure about another one though....
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 05-06-2004, 06:30 PM   #22
tin can luv
1976 27' Overlander
Images: 82
Originally Posted by 53FlyingCloud
Ron,
ciao
53FC
Ok, where can I pick one up at???? I'm an idiot you know.....
Old 05-06-2004, 06:32 PM   #23
tin can luv
1976 27' Overlander
Images: 82
Inspiring
All of these pictures of your shiney rigs are inspiring me to get out there, and quit worrying about the time it will take. It can be discouraging, I'm sure, but wow!!!!
Old 05-06-2004, 06:50 PM   #24
53flyingcloud
Try to enjoy life~
Ron,
You might try at Wal-Mart Store in your area..
This is where I found mine..
The effects of the light's refractions are just stunning~!
Blue LED works the best~
I hear you about the polishing efforts..It's sorta like copying "Morse Code", once you get over the initial barrier, the rest follows.
The work you've done so far on the interior has been fantastic~
ciao
53FC
AIR 807
Old 05-06-2004, 07:43 PM   #25
bevedfelker
Ed & Bev
Profile:
... the mortal enemy
They look great -- but polishing sure seems like it would be the mortal enemy of sitting under a tree and drinking beer.
Ed
bevedfelker is offline   Reply With Quote
Old 05-06-2004, 07:50 PM   #26
tin can luv
1976 27' Overlander
Images: 82
Now Ed & Bev....come on.....
Ed
I polish under a tree with a cold one ready everytime I step off the ladder!!!!
Old 05-06-2004, 07:50 PM   #27
tin can luv
1976 27' Overlander
Images: 82
Cool...
Ron,
I hear you about the polishing efforts..It's sorta like coping "Morse Code", once you get over the initial barrier, the rest follows.
ciao
53FC
I'm tired of polishing, Maybe I'll go get one now!!!!
Old 05-07-2004, 12:13 AM   #28
53flyingcloud
Talking Go for it~
Ron,
Just remember this trick works best on skin surface that "has not" been CYCLO'D~!
Best I can remember, the blue LED light was either in the Sports Dept or in the Auto Section..It's one of those "key-chain" type things. Which means, it's gonna cost more to replace the batteries than to buy a new one..lmao
ciao
53FC
AIR 807
SS Polish for sale, regular price Stefrobrts The Vendor's Forum 0 09-10-2003 11:30 AM
Southern Shine Metal Polish... trailertrash Cleaning, Stripping & Polishing 89 07-31-2003 05:33 PM
meguiars polish david h Cleaning, Stripping & Polishing 3 01-11-2003 01:42 PM
Best Polish to restore Airstream ?? bgow 1969 Overlander 1 08-06-2002 11:23 PM
