Old 03-30-2015, 06:37 PM   #1
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
That pesky decal glue!
I need everybodys feedback on the glue that hides in waiting under most RV Decals. Particularly the ones on fiberglass exterior walls. Laquer thinner seems to bond the exposed decal glue into the fiberglass wall itself- making it even harder to take up completly.
I know some you are rocket scientists...help!
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 03-30-2015, 06:43 PM   #2
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
"Shout"worked like magic on all the glue left under the labels on the counter top, fiberglass shower walls and Corian counter top.
George
gandttimes is offline   Reply With Quote
Old 03-30-2015, 06:45 PM   #3
1970 27' Overlander
You mean Shout like the laundry shout?
Old 03-30-2015, 07:11 PM   #4
r carl's Avatar
Lin , Ne
Try lighter fluid and a rag.
Old 03-30-2015, 07:19 PM   #5
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Yes.
George
Old 03-30-2015, 07:19 PM   #6
1970 27' Overlander
So far I have used Lacquer thinner and unleaded gas and 91 per cent rubbing alcohol. I will try the shout product tomorrow. Any more feed back out there?
Old 03-30-2015, 07:25 PM   #7
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
I use Goof Off Professional Strength for the stubborn sticky residue. I've tried Lacquer Thinner, Lighter Fluid (Naptha), Mineral Spirits, Goo Gone, WD-40, etc, etc. Goof Off is by far the best. Nasty stuff but works like a champ!
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 03-30-2015, 07:38 PM   #8
1970 27' Overlander
I have even tried Mayonnaise ...Maybe the Goof off will work too.
Old 03-30-2015, 08:02 PM   #9
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Really. Try the Shout. I didn't believe it either.
George
Old 03-30-2015, 08:26 PM   #10
1970 27' Overlander
Thanks all. If Shout works - I will do a back flip. (of course you will not see me do that. But I will be ecstatic to say the least) -Thanks again. I will report back tomorrow.
Old 03-31-2015, 06:33 AM   #11
1970 27' Overlander
Last question. There are three types of the Shout product - was there a certain one you used to do it?
Old 03-31-2015, 07:55 AM   #12
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
I think I steel wooled too hard, ouch! Now what?
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 03-31-2015, 09:14 AM   #13
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Sorry, didn't catch this one last night, and I am in the west.
Canadian "shout" I used just says"Triple Action". Can't see much else distinguishing on the label. Borrowed it from the laundry room.
George
Old 03-31-2015, 09:23 AM   #14
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Forgot to add Spray Bottle.
George
Those pesky beds in the back or where did I put my glasses? Caryl 2005 and newer - Bambi all models 16 09-18-2010 08:27 PM
Pesky cracks in bathroom ABS counter Lumatic Cabinets, Counter Tops & Furnishings 14 07-19-2009 09:24 PM
Two pesky leaks wacnstac Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 05-05-2006 12:19 PM
Those pesky fluffy thingies stinkytwinky Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 06-29-2005 08:02 AM
That pesky grey water that bypases the holding tank Van All Argosy Trailers 15 08-13-2004 07:52 AM
