Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 08-30-2005, 05:51 PM   #1
Gen Disarray
Gen Disarray's Avatar
Profile:  1968 24' Tradewind
Lawton , Oklahoma
Suggestions for cleaning/polishing options with little time?
I plan on taking my newly aquired 68 trade wind (24ft) on two trips this fall, the first one in about 3 weeks. I expect to be able to dedicate a total of 2-3 days to cleaning the exterior. From what I see here it doesnt look like a full blown polishing is in the cards. Given the time constrains, can anyone suggest the best appoach to making the trailer look its best? Is there a "sorta" polish proceedure or is soap and water the best I can do?
Rodney
On a magic carpet ride
Visit my photography page at:http://www.pbase.com/professor_chaos
Gen Disarray is offline   Reply With Quote
Old 08-30-2005, 05:58 PM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Does your trailer have it's clearcoat intact or is it failing or already been removed
If it were my trailer, and I didn't want to go the polishing route, I would do the following for each of the conditions noted below:
1. Clearcoat intact - wash with water & mild car wash type soap then apply a protectant like Walbernize products
2. Clearcoat failing - strip remaining clearcoat to remove milkiness
3. No clearcoat - wash with water & mild car wash type soap then apply a coat of Nu-Finish.
Hope this helps ~ other opinions will undoubtedly vary
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 08-30-2005, 06:21 PM   #3
silverleeper
silverleeper's Avatar
Profile:  1967 22' Safari
1960 18' "Footer"
Edmonds , Washington
Hi Rodney, I used a cleaner wax and then Wabernized. The cleaner wax to remover the years of stuff and Wabernize to protect and shine. I still have the old clearcoat thats failing in some spots. I'm happy with the results and I get complements on the shine... Happy days Lee
silverleeper is offline   Reply With Quote
Old 08-30-2005, 07:06 PM   #4
robandzoe
robandzoe's Avatar
Profile:  1958 30' Sovereign of the Road
1965 17' Caravel
Plymouth , New York
Images: 26
502T ICI Stripper
Get a gallon of this stuff and put it on, like paint, and let it sit for an hour, and power wash it off, and it'll remove the clear coat, and the trailer will shine pretty good. Then, after your trip, do the polish thing.
Rob
Rob, Zoe', Stanton, Bryce and Braedon Baker
WDCU President
Do you Listen to the www.theVAP.com
Plymouth, NY 13832 WBCCI #2820
Courtesy parking (607) 334 4960
58 30' Sovereign of the Road:
http://sweetsovereign.blogspot.com
65 17' Caravel, 54 22' Safari, 1959 Buick Electra
robandzoe is offline   Reply With Quote
Old 08-30-2005, 08:30 PM   #5
Gen Disarray
Lawton , Oklahoma
How do you tell if there is still clear coat?
Rodney
Old 08-30-2005, 09:52 PM   #6
Ferroequine
Ferroequine's Avatar
Profile:  1975 23' Safari
Calgary , Alberta
How to check if you have failing clearcoat
Check this thread. If your trailer's skin looks like ours did, then I agree that stripping it will give you the quickest result to something presentable. I stripped with a product similar to what robandzoe mentioned - you can see the results of this other thread.
1975 Safari 23'
2004 Ford Expedition Eddie Bauer 4x4
Ferroequine is offline   Reply With Quote
Old 08-30-2005, 10:02 PM   #7
InsideOut
InsideOut's Avatar
1956 22' Safari
Images: 87
The easiest way is to wash a small patch, then put some toothpaste on your finger and rub gently. If it turns black, no cleatcoat, if it doesn't it has clearcoat. The black is actually the oxidation from the aluminum, if it has clearcaot you won't remove any oxidation, thus no black.
You only need to test a very tiny area...it's best to do somewhere where it isn't very visable.
Also, if it has failing clearcoat, it will look very splotchy with milky patches...
Shari
Old 08-31-2005, 09:12 AM   #8
SC Overlander
Profile:  1971 27' Overlander
Lake Wylie , South Carolina
Another Clear Coat Question
Can anyone out there tell me if AS has always used clearcoat? I recently purchased a 59 Overlander and am just curious if the clearcoat was even applied back then
Jake
SC Overlander is offline   Reply With Quote
Old 08-31-2005, 09:44 AM   #9
silverleeper
1960 18' "Footer"
Jake
Hi, It was clearcoated back then. I'm not sure when AS started clearcoating the trailers. My 60 18 footer has it. Lee
Old 08-31-2005, 10:02 AM   #10
InsideOut
InsideOut's Avatar
1956 22' Safari
Images: 87
Hmmm...that's odd.
Based on brochures & price lists I've seen, I always believed it was a new option in 1964 and became standard in late 1965.
Could your '60 have had it added at a later date? Maybe it was optional prior to '64...
Shari
Old 08-31-2005, 10:12 AM   #11
silverleeper
1960 18' "Footer"
Shari
I'm not sure. The clearcoat is even under the trim pieces that didn't look like they have ever been removed. If trailer could only talk. Lee
Old 08-31-2005, 01:46 PM   #12
InsideOut
InsideOut's Avatar
1956 22' Safari
Images: 87
Oh the stories they would tell ~
Shari
Seeking plans for dinette FrankR General Interior Topics 24 05-01-2006 02:27 AM
MH pre buy suggestions jkleven Airstream Motorhome Forums 13 03-27-2006 08:21 AM
Suggestions Inland RV Center, In Our Community 5 10-30-2002 07:12 PM
New Microwave Suggestions 1985air345 Stoves, Ovens & Microwaves 3 08-30-2002 09:49 AM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 08:05 AM
