Old 06-13-2005, 08:56 PM   #1
TroutStream's Avatar
Stripping/Polishing the OILY
I picked up a Makita 9227 polisher and have begun the project. I bought some Heavy Metal Medium and Fine to try. I should have bought the course as well but I was told by the lady on the phone the medium would work. I would have gone for Nuvite but I had trouble sourcing it in Canada. I have also experimented on a couple of spots with Autosol. I wasn't planning on going for a mirror finish but who knows where i'll end up.
I used the POR-Strip and it worked unbelievably well.
My question is a difference in the way the side panel is turning out compared to the rear end cap. I polished each about the same yet there is a noticeable difference in finish to this point. The end cap is foggier.
Has this happened to anyone else???
Ken.
Name:	Foggy panel.JPG
ID:	12805   Click image for larger version
Name:	Foggy panel 2.JPG
TroutStream is offline   Reply With Quote
Old 06-13-2005, 10:50 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Hi Ken
Ken,
You should have some Heavy Metal course polish for this.
I usd some of their course on corrosion and endcaps, and it works very well. Following teh course with some medium makes most of the swirls very unobtrusive. Another pass with a cyclo and Nuvite S will give you a mirror finish.
The endcaps respond to polishing quite differently thant eh straight panels. It has to do with the way the metal was formed and stretched during manufacturing. It takes more effort to smooth out the pores on the endcaps. Normal, no worries.
Uwe
www.area63productions.com
Old 06-13-2005, 11:43 PM   #3
Ferroequine's Avatar
1975 23' Safari
Calgary , Alberta
Yup, the same thing happened with our endcaps. If you look at my avatar, you can see that they even looked different with the clearcoat on. In my case, a couple of rounds of compounding with C, and then cycloing with F7 (& C) did the trick. Now the cap and the side are just as shiny.
1975 Safari 23'
2004 Ford Expedition Eddie Bauer 4x4
Ferroequine is offline   Reply With Quote
Old 06-14-2005, 02:18 PM   #4
Thanks guys,
You know when I started the polish concept, I was just thinking of "shinier' and uniform, not mirror finish. But I can see that you get kind of obsessed with the shine.
Yikes!
Tongue jack crank problems TDOW Jacks, Stabilizers, Lifting and Leveling 3 06-10-2005 06:21 AM
Wd40!!!!!!! jjonesnc General Repair Forum 45 06-17-2004 06:11 AM
