02-05-2016, 04:00 PM
#401
1977 23' Safari
Carberry
, Manitoba
I've just started my strip/polish on my 77 safari. For stripping I am getting good success with the enviro friendly exterior stripper. I brush it on then cover with light plastic sheeting (comes in rolls for drop sheets), leave it on on overnight then scrape it off with a plastic scraper and wash with clean water. It strips easy. I have spot tested Nuvite C grade but it will not remove heavy oxidation, at least not without a lot of time. I am now going to try F9 nuvite, at least for the bad spots. I'm hoping the majority of my shell which still has the clearcoat will polish up fairly easily with only C grade. trouble is once you start to polish, you can't just touch it up the bad spots. My trailer has the low lustre finish from the clear coat and any polishing brings up a higher lustre. I don't think I'm up for going over the whole thing with Bon Ami later so will just live with the finish I get from C. Not a mirror finish but significantly shinier than the original.
YMMV - Lorry
02-05-2016, 09:08 PM
#402
1969 29' Ambassador
brooksville
I tried some G6 with the cylco for second cut. Came out pretty good, took the swirls out, reflective finish but not a perfect mirror.
02-12-2016, 05:26 PM
#403
1979 24' Airstream Excella 24
Tipp City
, Ohio
You have come this far. don't stop now. I think when you go to the nuvite 'C' the shine will really pop.
02-14-2016, 05:27 PM
#404
1969 29' Ambassador
brooksville
For the C, should I use the wool pads on the cylco?
02-16-2016, 02:53 PM
#405
Tipp City
, Ohio
With the C you are going to use a terry cloth pad covered with a cotton cloth that looks like sweat shirt material. You can probably use any kind of soft cotton rag to experiment and see how it works but, I would suggest you get the fleece wraps from Perfect Polish. http://www.perfectpolish.com/cloth.html They are just the right size and come with a clamp that is really handy to hold the fabric in place. Remenber just use a dab of C (like the size of a pencil eraser and always use fresh cloth for each section.
02-16-2016, 05:06 PM
#406
1969 29' Ambassador
brooksville
I noticed that G 6 leaves removes the swirls, but leaves a faint cloudiness, will the C remove that?
02-19-2016, 05:16 PM
#407
Tipp City
, Ohio
There is some controversy about what do after you polish with the wool pad and G6 or F7. I used 'C' on the 7" rotary polisher with the wool pad then 'Airbrite' (supposed to be the equivalent of Nuvite 'S') with the Cyclo. If you already did the Cyclo with G6 I would be inclined to try going straight to Nuvite 'S'. Maybe buy a small container of each and see how you like the results.
You have me a little confused. When you used 'G6' with the Cyclo what kind of pads did you have on the Cyclo?
It ain't easy but nothing worthwhile ever is....
02-19-2016, 05:58 PM
#408
1969 29' Ambassador
brooksville
The wool pads.
02-19-2016, 07:15 PM
#409
Tipp City
, Ohio
OK, I would definitely go to Nuvite 'S' or the Airbrite from VTS. Use foam pads with the terry cloth booties and the fleece wrap mentioned in the link above.
02-20-2016, 07:03 PM
#410
1969 29' Ambassador
brooksville
Great! Now just to find the time for the next cut....
04-02-2016, 05:35 PM
#411
1980 24' Caravelle
corpus christi
Did some spring cleaning and shining today. One side done will tackle other side tomorrow if time and weather permit.
11-25-2016, 02:06 PM
#412
1969 29' Ambassador
brooksville
White pad on cyclo
Has anyone ever tried the white pads on the cyclo with nuvite s, instead of the terry cloth?
01-18-2017, 01:05 PM
#413
Freeport
Hi I have a cyclo dual head polisher like New used one trip around a Bambi .. sold trailer don't need polisher .. does a great job for the mirror finish .. $275. 850-598-6300
07-08-2017, 07:00 AM
#414
White Rock
, British Columbia
What bonnet are most using with Nuvite "C" on a rotary polisher? Wool or foam?
07-09-2017, 06:59 AM
#415
1976 25' Caravanner
Salt Lake City
, Utah
Wool. I buy them at Harbor Freight. Same ones as are sold at high-end automotive paint stores, around here at least.
07-22-2017, 12:03 PM
#416
1969 31' Sovereign
1982 28' Airstream 280
Edmonton
, Alberta
Originally Posted by pond
Sorry to hear about your husband. Some articles say there are 200 hours of work from stripping to a beautiful shine, plus some specialized equipment like polishers.*
This thread is long but has a lot of info. The weather has to be *in the 60s or higher for the non toxic strippers to work.*
I had prices in LI NY from $10,000.- down to around $2,000.- if I stripped it and they would come and polish.*
Mike
I have phoned around also for prices and quite frankly the only honest way would be an extremely experienced company or hourly.
With contracts it's human nature to get the job done as quick as possible. A 200 hr job becomes a 140 hr.
09-10-2017, 04:17 PM
#417
1967 22' Safari
West Fork
, Arkansas
Except for completion of polishing, our 50 year old Safari is customized and mostly complete. One year ago I had the front end cap looking great and have just finished the rear end cap. Before starting on the middle sections I looked over the front again and was surprised to see spots on the upper portion. It appeared as if something impacted or deposited tiny spots that grew into hazy circles around each. Or maybe Chickenpox?
So far I've gone over it a couple of times with a vertical polisher using the Jestco 8" soft buffs and grey bar as well as Nuvite F9. Looks like I could use a more aggressive approach, have more patience or just consider the current finish the "patina of antiquity"
Suggestions?
09-11-2017, 11:12 AM
#418
1964 24' Tradewind
2006 39' Land Yacht 396 XL
Lawrence
, Kansas
Suggestions?
Patience. First time I did mine I did 14 cuts. I think 4 with F9.
09-11-2017, 12:05 PM
#419
1967 22' Safari
West Fork
, Arkansas
thanks ttbikes.
close up view attached.
09-12-2017, 08:52 AM
#420
1964 24' Tradewind
Lawrence
, Kansas
I should also tell you some spots I never got out but people are still amazed at the shine. I have spots like that but it IS not what people see. _DSC4767.pdf
