Old 02-19-2016, 05:16 PM   #407
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
There is some controversy about what do after you polish with the wool pad and G6 or F7. I used 'C' on the 7" rotary polisher with the wool pad then 'Airbrite' (supposed to be the equivalent of Nuvite 'S') with the Cyclo. If you already did the Cyclo with G6 I would be inclined to try going straight to Nuvite 'S'. Maybe buy a small container of each and see how you like the results.
You have me a little confused. When you used 'G6' with the Cyclo what kind of pads did you have on the Cyclo?
It ain't easy but nothing worthwhile ever is....
Gregsch is offline   Reply With Quote
Old 02-19-2016, 05:58 PM   #408
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
The wool pads.
Silverflames is offline   Reply With Quote
Old 02-19-2016, 07:15 PM   #409
Gregsch's Avatar
Tipp City , Ohio
OK, I would definitely go to Nuvite 'S' or the Airbrite from VTS. Use foam pads with the terry cloth booties and the fleece wrap mentioned in the link above.
Old 02-20-2016, 07:03 PM   #410
1969 29' Ambassador
Great! Now just to find the time for the next cut....
Old 04-02-2016, 05:35 PM   #411
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
Did some spring cleaning and shining today. One side done will tackle other side tomorrow if time and weather permit.
ID:	259832   Click image for larger version
thehandyman is offline   Reply With Quote
Old 11-25-2016, 02:06 PM   #412
1969 29' Ambassador
White pad on cyclo
Has anyone ever tried the white pads on the cyclo with nuvite s, instead of the terry cloth?
Old 01-18-2017, 01:05 PM   #413
Freeport , Florida
Hi I have a cyclo dual head polisher like New used one trip around a Bambi .. sold trailer don't need polisher .. does a great job for the mirror finish .. $275. 850-598-6300
Jimipat is offline   Reply With Quote
Old 07-08-2017, 07:00 AM   #414
White Rock , British Columbia
What bonnet are most using with Nuvite "C" on a rotary polisher? Wool or foam?
squareweave is offline   Reply With Quote
Old 07-09-2017, 06:59 AM   #415
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
Wool. I buy them at Harbor Freight. Same ones as are sold at high-end automotive paint stores, around here at least.
youngpeck is offline   Reply With Quote
Old 07-22-2017, 12:03 PM   #416
1969 31' Sovereign
1982 28' Airstream 280
Edmonton , Alberta
Originally Posted by pond View Post
Sorry to hear about your husband. Some articles say there are 200 hours of work from stripping to a beautiful shine, plus some specialized equipment like polishers.*
This thread is long but has a lot of info. The weather has to be *in the 60s or higher for the non toxic strippers to work.*
I had prices in LI NY from $10,000.- down to around $2,000.- if I stripped it and they would come and polish.*
Mike
I have phoned around also for prices and quite frankly the only honest way would be an extremely experienced company or hourly.
With contracts it's human nature to get the job done as quick as possible. A 200 hr job becomes a 140 hr.
Swillv8 is offline   Reply With Quote
Old 09-10-2017, 04:17 PM   #417
JRF0st3r's Avatar
1967 22' Safari
West Fork , Arkansas
Except for completion of polishing, our 50 year old Safari is customized and mostly complete. One year ago I had the front end cap looking great and have just finished the rear end cap. Before starting on the middle sections I looked over the front again and was surprised to see spots on the upper portion. It appeared as if something impacted or deposited tiny spots that grew into hazy circles around each. Or maybe Chickenpox?
So far I've gone over it a couple of times with a vertical polisher using the Jestco 8" soft buffs and grey bar as well as Nuvite F9. Looks like I could use a more aggressive approach, have more patience or just consider the current finish the "patina of antiquity"
Suggestions?
JRF0st3r is offline   Reply With Quote
Old 09-11-2017, 11:12 AM   #418
1964 24' Tradewind
Lawrence , Kansas
Suggestions?
Patience. First time I did mine I did 14 cuts. I think 4 with F9.
ttbikes is offline   Reply With Quote
Old 09-11-2017, 12:05 PM   #419
JRF0st3r's Avatar
1967 22' Safari
thanks ttbikes.
close up view attached.
Old 09-12-2017, 08:52 AM   #420
1964 24' Tradewind
Lawrence , Kansas
I should also tell you some spots I never got out but people are still amazed at the shine. I have spots like that but it IS not what people see._DSC4767.pdf
