Old 11-16-2013, 09:50 AM   #309
constructor's Avatar
1973 25' Tradewind
1960 28' Ambassador
New Smyrna Beach , Florida
Becky, I thought I read if you put anything over the polished finish it makes it harder to polish next time. We use the nuvite system with compounding and cyclo. We are finishing are 3rd polish in 2 years and each time we feel we get deeper and better.
You have good results with the Nu-finish keeping the shine and no interference on next polish?
Ann - The Constructor's scribe TAC FL-20
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover. - Mark Twain
constructor is offline   Reply With Quote
Old 11-16-2013, 09:52 AM   #310
1973 25' Tradewind
1960 28' Ambassador
Opps, I misread the question.
Old 03-28-2014, 07:31 AM   #311
1969 18' Caravel
Fort Worth , Texas
Hi Hey Hello you wonderful people! Great thread but now outdated as I can't find removall 220 or hydrostrip 502 anywhere!
My best attempt at finding something similar led me to Klean Strip aerosol aircraft peeler. I'm afraid if I have to buy cans, that'll break my bank even if I'm only dealing with 18 feet.
Anyone tried the Eldorado yet?
SarahCaravel is offline   Reply With Quote
Old 03-28-2014, 07:48 AM   #312
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
You can get gallon cans of Aircraft Stripper and Citri Strip at any Big Box store.
Now sit back and think about this....add up the costs of the materials...the tools...the learning curve....the "oops" repairs.....the aggravation and the far more work involved. Compare that to spending 2000 dollars and its all done two weeks after you drop it off or have it done at your place.
The good news is that if you are going to do it yourself in Texas...this is the time.....before the heat.
Old 03-28-2014, 05:27 PM   #313
1969 18' Caravel
Fort Worth , Texas
Yes I can get a gallon of klean strip stripper, but called the company and they said it may pock and discolor aluminum. The aircraft peeler, they said, will not.
Old 03-28-2014, 08:12 PM   #314
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I guess I can't speak for everyone or every circumstance, but the full strength Kleen Strip Aircraft Remover produced no adverse effects on the aluminum where I used it on my 72.
Old 03-30-2014, 08:53 AM   #315
jonplayers's Avatar
Terrace , British Columbia
True That!!! I have probably spent $1000 plus on supplies and equipment.
I have also suffered much aggravation! Oh well at least next time it will be easier.
jonplayers is offline   Reply With Quote
Old 04-10-2014, 12:29 PM   #316
1969 18' Caravel
Fort Worth , Texas
Ok well, you talked me out of the strip and shine as I don't have 2k. I figured I'd try a wash and wax first, picked up some Meguiars and walbernize (convinced I got the last bottle of that in the metroplex.) Thought maybe I could get her shiny and beautiful enough. I'm now halfway through my wash and was hoping the black stuff on top would come right off. (Of course not.) Today I wash and tomorrow I wax. Is this oxidation? The previous owner kept her under a tarp and I'm fairly certain that's where the markings came from. Anybody think I'll be able to get those marks off without stripping?
Old 04-10-2014, 12:44 PM   #317
reinergirl's Avatar
Hollis , New Hampshire
Oxidation on aluminum is white, if you are seeing black it's probably mold. I have had great luck using the Mr Clean magic eraser sponges found at any grocery/hardware store.
reinergirl is offline   Reply With Quote
Old 04-10-2014, 12:59 PM   #318
1969 18' Caravel
Fort Worth , Texas
Oh man that would be so rad if Mr. Clean would get rid of the black. Alas. I just tried it. No difference.
Old 04-10-2014, 01:03 PM   #319
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
I have similar marks on my trailer they are from a tarp rubbing on it also. Just washing will not remove them. Used some alum polish to remove them so they don't look so bad. Will do the entire trailer some day but that is low on the list.
thehandyman is offline   Reply With Quote
Old 04-24-2014, 02:08 PM   #320
1962 19' Globetrotter
Vancouver , British Columbia
Name:	ImageUploadedByAirstream Forums1398369902.194475.jpg
ID:	210455Click image for larger version
Name:	ImageUploadedByAirstream Forums1398369925.631435.jpg
ID:	210456Click image for larger version
Name:	ImageUploadedByAirstream Forums1398369946.944041.jpg
ID:	210457Click image for larger version
Name:	ImageUploadedByAirstream Forums1398369978.284648.jpg
ID:	210458Click image for larger version
Name:	ImageUploadedByAirstream Forums1398370000.656732.jpg
So where does this guy start?
Bought brown white and black compound bars from caswell plating.
I've got a whole 62 globetrotter filled with deep scratches pitting etc. I have time! For the best job possible I can achieve, do you recommend wet sanding this entire thing before even starting with these bars??
Stupidnoob is offline   Reply With Quote
Old 04-26-2014, 05:00 PM   #321
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
I've finally decided to strip the plasticoat off of our '64 Globetrotter, but I'm having a hard time finding the PPG Eldorado PR 5044, and I don't really want 5 gallons of it. I wondered if anyone had experience with other products, like EkoStrip from Stewart Systems, or MultiStrip from Home Depot? My plan is to strip it and, figuring it will look better and more even than it does now, leave it like that.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 04-26-2014, 11:02 PM   #322
Aircraft stripper, is one of the best. You can buy it one gallon at a time.
