Old 02-15-2012, 08:16 AM   #281
TeamD's Avatar
1968 24' Tradewind
Canoga Park , California
Did you remove your awning? I love all of the posts thank you!
TeamD is offline   Reply With Quote
Old 02-17-2012, 02:37 PM   #282
1974 27' Overlander
rochester , Michigan
I just purchased a 1974 overlander and enjoyed reading about the exterior polishing. I called a company in Ohio and the charge $250 per foot to finish which would be $6500 in my case. Think I will give it a try myself. One question, after you removed the clearcoat do you polish it with a wheel or wax it....?
freerider is offline   Reply With Quote
Old 02-17-2012, 02:41 PM   #283
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
If you do it right after the clearcoat comes off use mild abrasive IMO not wax
'77 Sovereign Intl 31' CB
Old 04-25-2012, 09:46 AM   #284
stream lady's Avatar
1975 Argosy 20
new iberia , Louisiana
Blue stripe on 1994
The clear coat was very bad on our 94 so we have taken it off and plain to polish, {after checking on having it redone} now what is the best way to remove the blue stripe?
stream lady is offline   Reply With Quote
Old 05-17-2012, 03:50 PM   #285
1968 24' Tradewind
Calistoga , California
I just bought my first vintage AS and want to get the exterior somewhat more appealing - but minus the $3500 polishing price tag for now. If I remove the clear coat and DON'T polish it until 6 months later, will I damage anything?
Wine Garage is offline   Reply With Quote
Old 05-17-2012, 03:54 PM   #286
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Yes oxidation will start, you must wax it.
Old 05-17-2012, 05:23 PM   #287
1968 24' Tradewind
just any old car wax?
and thanks.....
Old 05-17-2012, 10:03 PM   #288
Ottawa , ON
You won't damage it, and it will look much more uniform than that patchy look that occurs when the clear coat starts coming off all by itself.
But it will go dull.
Walbernize is one wax made for Airstreams...
Old 07-23-2012, 11:58 AM   #289
Jenniflow's Avatar
1982 34' Limited
1986 34.5' Airstream 345
Sausalito , California
Send a message via Skype™ to Jenniflow
Question What if I'm sandblasting a mural on the skin?
What a great thread! I think I've read all of it but now I'm already forgetting some of it. Could be because I personally am just hitting the national speed limit and my brain doesn't work the way it used to, so forgive me if I repeat a question here that I should know the answer to.
I am about to strip my 1986 345 coach and went to VintageTrailer. They're selling Removall 220 for $49.95 whereas they're saying the list price is $69.95. Cool. All the reviews for the product are great except for one guy who is claiming it doesn't work for newer aluminum coatings. Well, that doesn't apply to most of us anyway, but I thought I'd mention it here in case it's relevant to someone. He also may just be a spoiler or competitor.
I also talked with Adam at Avalon RV in Benicia and I told him I was planning to use Removall, and he mentioned that if I'm planning to replace the gaskets on the windows I should do the stripping first. He also said to cover the lights, etc. I guess for the same reason, as I believe others have mentioned. Just reporting in case this conflicts with your info.
So here is my main question:
I am planning to sandblast a mural into the skin of my coach. Yes. That's what I said.
If I take off the clearcoat and etch or sandblast the skin:
1) What is the best way to preserve and maintain it? Wax? Liquid sealer?
2) A related question, which is of these is more likely to screw up or gum up the textured part of the surface more?
3) Will one or the other retain more dirt?
4) And, looking down the road maybe 5-10 years, will I wish I had polished it first (because I can never do so again without screwing up the design? 5) Would there be any lasting effect of polishing after a while, including, maybe, a persisting higher contrast with the textured surface?
Whattaya say to that, oh oracles of the aluminum fraternity (loosely speaking)?
Jenniflow is offline   Reply With Quote
Old 01-08-2013, 08:58 AM   #290
2013 27' FB Classic
Woodstock , Georgia
How do you recoat after stripping off the clear coat? How long does it last?
jsaucer is offline   Reply With Quote
Old 01-13-2013, 11:09 AM   #291
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
J: I believe the re-clear coating process would be very similar to that of painting the trailer, as that is essentially what you are doing....."painting" it with a clear coat.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 01-13-2013, 11:15 AM   #292
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
I have seen a product called "sharkhide" that can be used for protecting aluminum. I have not used it, but have heard good things. I believe i saw a thread that had pictures of an AS with sharkhide applied...worth a quick search!
http://www.sharkhide.com/
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 02-17-2013, 07:35 AM   #293
Sanford , Florida
Cyclo alternatives
Hi there! Just bought a 1974 Sovereign that needs a ton of work. I'm converting it into a food trailer. I've been reading many of the posts on polishing and I'm wondering if a random orbit sander/buffer is a viable alternative to the Cyclo Polisher? I really don't want to spend that much money on a tool I don't use very often. I'd like it to be nice and shiny but I need to use my money on converting the inside into a mobile kitchen.
Thanks!
SurlyQue is offline   Reply With Quote
Old 02-17-2013, 07:39 AM   #294
constructor's Avatar
1973 25' Tradewind
1960 28' Ambassador
New Smyrna Beach , Florida
You need the cyclo if you plan to stay shiny.
Ann - The Constructor's scribe TAC FL-20
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover. - Mark Twain
constructor is offline   Reply With Quote
