Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 05-07-2005, 10:21 PM   #1
Ferroequine
Ferroequine's Avatar
Profile:  1975 23' Safari
Calgary , Alberta
Strip 'n Polish Project Thread ( lots of great tips and links)
Well, since it is finally somewhat nice outside , I thought I'd try out a test section of stripping the trailer. Over the next few weeks & months, I'll be stripping and then polishing our 1975 Safari. I'll keep updating this thread also.
It is a continuation of this thread, where I struggled with what to do with the exterior. Many thanks to all those people who helped on that thread.
I bought 4 gallons of Napier Removeall 220. It is fairly thick (like paint), and you brush it on. We left it sitting on the door for about 1 1/2 hours, and then we just hosed the paint off with the garden spray nozzle. The nice thing is that it doesn't appear to hurt the grass, since there is no solvent involved, and there was no smell. The water deactivates the catalyst (which I believe is Peroxide based), and all the stripped clearcoat ends up dripping onto the ground with the water.
Another nice surprise was that we 'painted' the Removeall 220 right over the pinstriping, and it didn't affect it at all!
ID:	12033  Click image for larger version
ID:	12037  Click image for larger version
1975 Safari 23'
2004 Ford Expedition Eddie Bauer 4x4
Ferroequine is offline   Reply With Quote
Old 05-10-2005, 10:03 AM   #2
Ferroequine
Calgary , Alberta
I tried the lower section of the door last night, to see how it would work. I didn't have any wool compounding bonnets yet, so I quickly cyclo'd it with the medium grade Nuvite. It turned out great for 5 minutes of work. I can't wait to get started this Saturday, barring any poor weather!
1975 Safari 23'
Old 05-10-2005, 10:48 AM   #3
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Very Nice>>!!!<< Currently working on my 75 Trade Wind 1/2 done the first pass. Looks great too!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'77 20' Argosy MH (Peanut)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is online now   Reply With Quote
Old 05-10-2005, 11:02 AM   #4
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
Looking good. You're on your way!
I'm about 2/3 done with my yearly cycloing and wax job...
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 05-12-2005, 09:17 PM   #5
Swanny
Swanny's Avatar
Profile:  1990 34' Excella
Windcrest , Texas
Unhappy Removeall 220
Your project is looking great. I've got a 31 ft Excella 500 that I'm debating on stripping and your thread caught my attention. If I read you correctly, this stripper was a 'brush on' style and you simply washed it off. How much scraping did you have to do after washing the area? Also, where did you get the Removeall 220?
Thanks again since I want to have my ducks in a row before trying to tackle this job.
Texas Streamer
1990 Excella 1000---34'
WBCCI #18303
2005 F-350 Diesel 4 X 4
Swanny is offline   Reply With Quote
Old 05-12-2005, 10:44 PM   #6
bake315
bake315's Avatar
Profile:  1994 34' Limited
Elgin , Texas
Images: 161
Swanny -
ICI Paints carries this as Hydrostrip 502 - same product as the Napier under a different name. The ICI dealer in Round Rock had it in stock. I'm sure there would be an ICI dealer down your way.
Cheers, Dave
"Finish."
AIR #4188
1994 34' Limited / 2002 Chevy 3500 CC 4x4 D/A Equal-i-zer Hitch / Jordan Ultima 2020
bake315 is offline   Reply With Quote
Old 05-13-2005, 05:10 AM   #7
balrgn
balrgn's Avatar
Images: 74
You might want to consider using Por Remover /Stripper For my 1975 25' I uses less than 1 1/2 gallons. Spray it on (they give you a bottle) and wait 30 or so seconds and scrape it off with a plastic scraper. It is unreal how fast it works. Second application, to get what stays stuck I used scotch brite.
Just a thought...
Member of VAC
www.balrgn.com
Old 05-13-2005, 09:22 AM   #8
Ferroequine
Calgary , Alberta
Swanny,
I pretty much had to do no scraping at all. There were a couple of spots where I hadn't covered the skin properly, so it didn't strip everything there, but that was more my fault. A bit of a wipe with a rag over the whole door, and she was ready to go. I couldn't believe how easy it was. It makes the $50/gal price worth it.
1975 Safari 23'
Old 05-13-2005, 10:38 PM   #9
Swanny
Swanny's Avatar
Windcrest , Texas
Thanks to everyone for the great tips. I think I'm sold on going with the polishing route. On another note, this model of AS has a 5-6" wide blue stripe all the way around it. When I rub my fingers across it, it feels like vinyl.
Any idea of what this material is and how do you suggest treating it? My hunch was to use Armorall or something of that nature. Thanks again for all of your tips.
Mitch
Texas Streamer
WBCCI #18303
Old 05-15-2005, 11:27 AM   #10
Ferroequine
Calgary , Alberta
I did some more stripping yesterday. Did the entire endcap, and one of the sides. This is sure an interesting stripper. You leave it on for a couple of hours after painting it on thick. Then from a distance it looks like it's dry, but if you look really close, you can see it crystalizing.
Hosing it off afterwards is fairly easy. However, a pressure washer would be nice to have.
ID:	12129  Click image for larger version
1975 Safari 23'
Old 05-15-2005, 05:25 PM   #11
Safari Tim
Safari Tim's Avatar
Images: 35
I don't know what stripper your using, but I don't think your supposed to leave it on that long. Probably 10-15 minutes is enough.
-Tim
Old 05-15-2005, 06:42 PM   #12
balrgn
balrgn's Avatar
Images: 74
That does seem long? The stuff I used was spray on after 30 seconds wipe off. took less than 3 hours to do the whole unit... (1 1/2 gallons did the trick)
Do think the metal may be etched?
Member of VAC
www.balrgn.com
Old 05-15-2005, 08:41 PM   #13
Ferroequine
Calgary , Alberta
The stripper is Peroxide based, and not a solvent. Boeing approves the product as well for all of their planes. Tom @ Perfect polish said to leave it for a couple of hours, although I have found an hour to be enough. Some guys with airplanes apparantly leave it on for up to 4 hours.
It didn't etch any of the side panels as far as I can tell.
1975 Safari 23'
Old 05-15-2005, 08:43 PM   #14
Ferroequine
Calgary , Alberta
Re: the picture above with the crystalizing -- it hosed right off and came out with nice clean, smooth aluminum.
1975 Safari 23'
tips for Newbies femuse Link Archive 0 05-14-2003 12:54 PM
Frequently Asked Questions about towing femuse Towing, Tow Vehicles & Hitches 3 04-19-2003 10:29 PM
