Old 07-08-2006, 12:27 PM   #1
ft collins , Colorado
can I strip clear coat w/out polishing
Just bought a 78 and was wondering if it was possible to just strip the clear coat off now and wait until winter to do the polishing? Thanks for your help.
Bridger
bridger is offline   Reply With Quote
Old 07-08-2006, 01:31 PM   #2
1972 25' Tradewind
Wentworth , South Dakota
This is America! You can do anything you want.
I'm planing on doing this so I hope no one spoils the idea.
Danetree is offline   Reply With Quote
Old 07-08-2006, 02:57 PM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
After the strip a little car wax would protect it for a while so it would be easier to get a good result later when you may decide to really polish it. depending on the size you could be in for quite a bit of work.
Old 07-08-2006, 03:46 PM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
some strip and wax or coat with sealant by hand and don't ever really polish, yes there are those of us who are not enamored with the mirror look. While it is way cool, of course...we like a more subtle satiny finish.
You might find when the clear is off a little wax will give it a great look. The wax doesn't last real long in the sun, so you might opt for a polymer sealant like Liquid Glass, or Meguirs, etc.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 07-08-2006, 06:26 PM   #5
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
No problem!
We stripped ours and took about two summers to polish it (are you ever really "done").
I too know of several who have found that stripping and just waxing is a-okay with them. It depends on the integrity of your clearcoat...if it is real splotchy, then parts of the exposed aluminum may have oxidized for longer than others, which will give you a shiny vs less-shiny splotchy look even after stripping. If the clearcoat has failed evenly, then you may find your aluminum pretty evenly patina-ed and not want or need to polish at all as the aluminum under the clearcoat was protected.
Regardless, keep in mind that really oxidized areas have been developed over years of exposure, not weeks, so a couple of months won't make a difference in your overall polishing effort no matter what method you choose.
Shari
Old 07-08-2006, 07:25 PM   #6
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
I've been working on the roof vents this summer and found it necessary to strip back the clearcoat to remove the PO's silicone sealing attempts. The skin under what I thought was pretty badly damaged clear looked great.
While I resprayed with automotive clearcoat, because I'm not at the stage for a strip and polish, I would say try a small roof panel, which usually deteriorate first, and check it out. Couldn't hurt anything, you'll get to check the skin, and, can be redone if you have to.
Good Luck,
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Clear coat finish on top James Schmidt Clearcoat, Exterior Paint & Trim 7 06-14-2006 09:26 PM
Which clearcoat? Bob Thompson Clearcoat, Exterior Paint & Trim 13 05-27-2004 06:36 PM
Paint Removal from side of A/S Lexxy Clearcoat, Exterior Paint & Trim 2 08-19-2002 07:03 AM
Anyone else polishing? 64GT Cleaning, Stripping & Polishing 24 08-08-2002 09:19 AM
Condition of Clear coat James Schmidt 1993 Excella 1000 2 05-15-2002 08:23 AM
