Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 02-16-2006, 12:01 AM   #1
Profile:  1962 16' Bambi
Phoenix , Arizona
strip clear coat
Any suggestion for a product that removes original clear coat on vintage Airstream? (Do I use a paint stripper?)
baobi is offline   Reply With Quote
Old 02-16-2006, 12:55 AM   #2
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Airstream Registry
I don't believe a '62 Bambi has original clearcoat. It wasn't an option until 1964...
Regardless, if you want to get it off easily, use Kleen Strip Aircraft Stripper. It's available at Pep Boys, Home Depot, etc. Be sure to read all the warnings, this stuff is N-A-S-T-Y but it works! There are milder chemicals and other methods, if you do a search of the forums using "stripper" or "clearcoat stripping" you'll find lots of info that will give you many options.
Oh yeah, welcome to the forums!
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 02-16-2006, 05:45 PM   #3
airstream4's Avatar
Profile:  1997 34' Limited
1963 22' Safari
Troy , Michigan
Use removall , no smell, non toxic, Brush it on , let work rinse off with hose or powerwasher. I've used on two trailers and it works great! One gallon should do a 25' trailer. Manufacturer says to spray on, but I have brushed on with great success. Search on google for Removall they may have a local distributor. I ordered on line thru Boston restoration.
Paul
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
Old 05-28-2006, 05:29 PM   #4
Profile:  1979 31' Sovereign
Baton Rouge , Louisiana
Images: 42
Stripping Clear Coat
Baobi - Saw your post about the clear. It's funny that I saw your post today! I just finished (2 hours ago) completely stripping my Sovereign. I used BIX Tough Job stripper from Home Depot. It's $19 a gallon, which I thought was a bargain and it specifically lists aircraft metal as a use. It's caustic as all get out so you have to use rubber gloves and watch your skin and eyes. You just paint it on with a paint brush, let it sit for 15-30 minutes and then hose it off. No scraping and no fuss. It's a semi-paste gel (I started calling it caustic snot about two hours into the job) and it sticks real well on the verticals. It's a water clean-up product so if it gets on your skin, just wash it off and it's gone. All in all, I was real happy. It took me about 4 hours to do a 31' Sovereign that had about 80% intact clear on it. -Don
cobra93 is offline   Reply With Quote
Clear coat finish on top James Schmidt Clearcoat, Exterior Paint & Trim 7 06-14-2006 09:26 PM
Which clearcoat? Bob Thompson Clearcoat, Exterior Paint & Trim 13 05-27-2004 06:36 PM
Paint Removal from side of A/S Lexxy Clearcoat, Exterior Paint & Trim 2 08-19-2002 07:03 AM
Ouestions 2-oxidation&clear coat Sharon Lee Cleaning, Stripping & Polishing 0 07-01-2002 08:20 AM
Condition of Clear coat James Schmidt 1993 Excella 1000 2 05-15-2002 08:23 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
