Old 10-05-2016, 03:23 PM   #1
1977 31' Excella 500
NEW HARTFORD , Connecticut
Strip Before or After Leak Sealing?
Just brainstorming, it's seems logical to me to strip the plastic coat (and I guess clear coat too?) before I seal it, so that the stripper doesn't eat away at any new leak stopping I've put in. BUT my fear is, since it is leaky, won't the stripper get in overlaps and be essentially sandwiched, causing more corrosion?
Also what product did you use and did you love or hate it ?
Thanks!!
stormbornSG is offline   Reply With Quote
Old 10-05-2016, 06:39 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I stripped my two trailers before leak testing and sealing. I also polished the trailers before leak testing and sealing. I found Aircraft Stripper found at auto parts stores and the like was effective in cutting the old clear coat off. I did not find that Aircraft Stripper harmed the aluminum skin in any way. It will eat the vinyl stripe around the beltline of the trailer, so be careful there.
I ended up using a bondo plastic scraper to scrap the stripper and clear coat off the trailer and deposited it in a little drywall mud pan. Then I collected it for safe disposal. I did a section at a time. I then rinsed the trailer with water.
I found the stripper was not effective on caulk, sealants, or silicone. Those old sealants basically have to be mechanically removed. "Pick'in and grin'in".
There are others who have a better process than mine. But this worked for me.
David
Name:	1311 Stripper Working 2.jpg
Old 10-05-2016, 09:58 PM   #3
David
Thanks for the info, I'll have to improvise something for the blue strip.
What does sealing an Argosy before paint look like woodlandfarm All Argosy Trailers 4 12-05-2013 07:33 PM
Help! What's a "sealing strip?" usuallyalex Refrigerators 7 08-21-2013 09:17 PM
Cleaning before re-sealing? cameront120 Cleaning, Stripping & Polishing 14 04-06-2006 08:57 PM
To strip or not to strip. That is the question. mjmcwhorte Cabinets, Counter Tops & Furnishings 2 01-16-2006 09:10 AM
leaks-after sealing coastal me Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 10-01-2005 02:29 PM
