Old 11-25-2005, 07:15 PM   #1
Julison's Avatar
1969 18' Caravel
Ottawa , Ontario
Strip & Polish ..In the Winter
Hi,
Winter is here in a very big way.... lots of snow and cold.
Has anyone ever tried to use std polish techniques in sub zero weather? I wouldn't mind trying to get this trailer polished over the winter.
I'm thinking it would be real nice to watch the snow melt next April and see the polished Caravel shining through!
thanks
Julison
Julison is offline   Reply With Quote
Old 11-25-2005, 08:18 PM   #2
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Its not a good idea to polish unless the temp is 60-65 degrees, most polishes will not work well below that
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 11-25-2005, 09:50 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
...unless of course you are polishing in a tempurature controled environment, like in a heated building/barn/shed, etc.
Shari
Old 11-26-2005, 09:22 AM   #4
1974 25' Tradewind
Yelm , Washington
Julison - There is a good "brainiac" but quick and dirty explanation about the effects of temperature on chemical and other physical reactions.
The basic rule is that there is a dynamic increase in effectiveness when temperature increases. The bottom line is that depending on the composition of the compound warmer is better because the compound is reacting with the metal.
Also, the metal will be much colder than the outside air or hotter than the outside air depending on conditions and that is a consideration. In cold weather your AS will be even colder on the surface than the air temperature.
If you do it in the winter is sounds like you might work harder or not get optimum results, but anything is possible.
Look at the site. Its interesting.
http://www.800mainstreet.com/7/0007-005-rea-t-cat.html
"It takes a village to raise a silver twinkie."
-Jim Phillips
JimmyJames is offline   Reply With Quote
Best Polish to restore Airstream ?? bgow 1969 Overlander 2 07-30-2009 11:04 AM
Airstreams in winter?? Curtis-79MH Airstream Motorhome Forums 6 03-27-2006 12:58 PM
Old polishers take note Bradjun1 Cleaning, Stripping & Polishing 3 06-08-2005 04:06 AM
Winter in an Airstream ????? Boris Carlove Our Community 9 08-04-2002 07:58 AM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
