many threads here on removing letters, decals, emblems, wb #, tar and so on...
search
'adhesive removal' or related terms...
i peeled the 'thor' sticker off...
b4 signing the purschase documents...
the gold LTD lettering came off last year at salem...
between 100 and 104.5...
as many have noticed
most of the a/s lettering came off the front cap this spring...
eventually all the lettering will be naturally gone except for the cheesey 'classic' belt buckles that are riveted.
wd/40 will work
many veggie oil products will work (mayo, p/butter)
most citrus oil (goo/goof) products will work...
on older adhesive these things usually need to soak awhile.
after using any of these, the residue still needs to be removed with surfactant/soap...
i use the 2 products pictured, so does a/s...
the sd/20 is not widely available but more 'air friendly' and used every day at the factory and in the service center...
the sd/20 is safe for all interior and exterior surfaces on newer units...
the 3m product really requires gloves and ventilation but is safe for the clearcoat.
a few hardened/baked/petrified bits may be left regardless what solvent is applied...
for these hard bits an auto clay bar like mother's clay or clay magic works great...
cheers
2air'
