Old 11-29-2011, 09:28 PM   #43
Thanks Zlee!
A little more progress...
And I think some cool pics of a Sunset!
Old 11-30-2011, 11:41 AM   #44
Oh, and finished the last of the rear upper marker lamp castings, and its ready for refitting fitting/sealing.
Before..
After..
Old 12-11-2011, 10:39 AM   #45
2006 19' International CCD
1971 31' Sovereign
Bonner Springs , Kansas
is there an update? what a huge job. I heard it's a 600 hour job, true?
iairstreamkc is offline   Reply With Quote
Old 12-11-2011, 02:49 PM   #46
Originally Posted by iairstreamkc View Post
Is there an update? What a huge job. I heard it's a 600 hour job, true?
I may be a 600hr job, I dont know, nor care to know!
Its just gotta be done, as the old finish is toast, and I see no reason to strip and replace the clearcoat...
I have my parent visiting for the Holidays, so not done much the last few weeks, but have not been idle... Each of the AIRSTREAM letters have been cleaned, stripped, and the rivet holes enlarged to take a screw rather than a rivet, so I can remove them when i retouch the polish.
I will get going on it again soon..
But for the sake of opinions, and giggles...
Pic taken of the Streetside rear corner the day I bought her in KS...
And now, as posted before for comparison...
Anyone have an opinion on if the effort will be worth it?
Old 12-11-2011, 03:09 PM   #47
JodyoD's Avatar
Folsom , California
Images: 21
Such a beautiful job! Looking GREAT!!! Can't believe you're doing it there in the lot...makes it that much tougher than if you can be at home and work on it when you have a few minutes. You must have the kitchen well stocked in it though...hahahaha! Keep up with the pics. I'm enjoying watching the progress. Have a good visit with family. Merry Christmas!
JodyoD is offline   Reply With Quote
Old 12-11-2011, 04:29 PM   #48
Thanks for the encourgement!
Its kinda double tough, as I have no electricity at the yard, AND the rear bedroom floor is partially out, which made me have to pull out the Transfer switch from the genset... which means I am using my 3.5KW portable sitting the the back of my old K10 Pickup, to power the buffer..
As I posted before or over on my main thread, to some, what I am doing might seem odd, and putting the cart before the horse... polishing before I have other stuff done..
Problem is, I had a water leak from somewhere in the rear cap, as water was running down on the streetside rear corner inside and the floor is toast. I cant replace the floor until I have it sealed, and need to polish before I seal each joint and window!
Everything I remove or fix is restored and sealed before replacement... like the tail lamp assembly, so it takes more time than it appears..
Before...
After...
We are getting more rain in the next few days, so I will be over there with my flashlight looking for water leaks tomorrow, but last time it stayed dry!
I still have a leak on the curbside, and will be up and looking for clues while its raining!
What is MOST frustrating is that SOB parked next to me... he is refusing to move spaces, so I am stuck with it...
I may turn the Airstream around, so I can complete the paint stripping and buffing without risk to his rig... The white Van on my curbside is also my spot, so no worries, but then it will be tricky to use my entrance door because he parked skewed!
Old 12-11-2011, 06:38 PM   #49
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
That is one nasty hole in the right rear ABS fairing, how do suppose that happened, AND, what's the plan to fix it?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 12-12-2011, 09:13 PM   #50
Yup, both sides are toast, so will be repairing them, and taking a mould.
Raining today...
Dont you love it when the rain beads off the polished sections!
Can help posting these pics!
Old 12-13-2011, 07:08 AM   #51
la nomade's Avatar
2018 22' Sport
stanfordville , New York
what a good job
Originally Posted by c_lewis77 View Post
Looks great!
.i have to start stripping and polishing mine in the spring,too cold now in n.y. looking at the result of your hard work is inspiring but also intimidating...i will have a lot of questions for you then,the pictures help understanding the process..good job,bravo
la nomade is offline   Reply With Quote
Old 12-13-2011, 07:19 AM   #52
la nomade's Avatar
2018 22' Sport
very inspiring ....wish i could bring mine up where you are to work with me on mine!!!!!it looks so overwhelming
Old 12-13-2011, 11:18 AM   #53
As you can see from the before pics, I really had no choice!
As those who have gone before will tell you... its kinda addictive!
Once you start seeing what is under that dull grey you just keep going.
I think stripping is tedious, and those that will need to protect other areas, VERY tedious, and worrisome.
I found satisfaction in removing that faded clearcoat to reveal the bright aluminum, but its nothing compared to the polishing.
I suggest you set yourself a goal per session.. or set a timer.
I started to strip one panel or to a line of rivets, and washed it down, then prepped and put the stripper on the next section, while I polished the first... Then prepped and let the stripper work on the 3rd section while I buffed the 2nd... If that makes sense!
Be warned... that buffer is a brutal training partner, and holding a nice steady pressure seems easy, but when it catches an edge or wanders, it uses muscles you forgot you had!
I just turned 50, and am 6' 4" and 225lb, and in pretty good physical shape.
I jog, and walk with my dogs between 3 and 8 miles every day..
After the first couple of hours buffing, I sleep like a baby and woke up feeling like I went 3 rounds with Mike Tyson!
Its getting better, and I am enjoying the challenge tho!
Maybe I should do a training DVD for Aistreamers wanting to get Buff!
Old 04-02-2012, 07:22 PM   #54
MaryContrary's Avatar
1984 31' Airstream310
on the road , CA and OR this summer!
Images: 41
quanity used?
beautiful job!...i'm ordering nuvite and saw your review on vintagetrailersupply for g6
btw how many .lb tubs have you gone through for each grit?
1984 310 Limited Motorhome
my AS Moho blog
for the love of all vehicles round and shiny
MaryContrary is offline   Reply With Quote
Old 04-02-2012, 08:39 PM   #55
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
Keyair: how is the polishing coming along?
I got inspired by your thread and polished mine too! What a difference!
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 04-03-2012, 11:15 AM   #56
Thanks Mary!
On my 3rd of G6, and love the stuff... more to go. My best estimate would be about 8 x 1lb pots will be needed based on what I have done and what is left. Only used a little of the Nuvite F so far.
Thanks C_Lewis77!
In fact I had watched your progress ands looks like we inspired each other!
Not much progress recently, as I had got bogged down with other pressing issues... But will be back to it soon I hope!
Strip & Polish 89 Excella 32' cjack99 Cleaning, Stripping & Polishing 14 04-06-2012 11:03 AM
Motorhome versus Trailer Member Search crzycpa Our Community 1 08-23-2011 01:30 PM
Seal or Polish first JIMandPJ Ribs, Skins & Rivets 4 03-15-2011 12:58 AM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 06:00 PM
