Old 10-08-2012, 11:44 PM   #127
tinyhome's Avatar
Victoria , Texas
Is there anything more beautiful then a vintage polished airstream?
tinyhome is offline   Reply With Quote
Old 10-09-2012, 04:14 AM   #128
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
Nope
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 10-09-2012, 07:26 AM   #129
1971 29' Ambassador
guyton , Georgia
zephyr.com the wed site
r.swanson is offline   Reply With Quote
Old 10-09-2012, 10:15 AM   #130
In the RV/MH world, there is no equal.
Having said that, I prefer a Polished Vintage Classic Airstream Motorhome..
I maybe a little biased, I will admit, but the one thing that ruins the look of the Airstream Trailer on the road... is the Tow Vehicle!
I have not YET seen a TV that I think enhances the look of the trailer...
Sounds like a great thread to me for the trailer section!
We have been discussing what would make the best looking toad for the M/H.... and it is yet undecided...
I think a Shelby Cobra with the the aluminum body.... polished, of coarse!
Like this one...
But the reality is that we decided that it needs to be a 4x4...
So this is the favorite for now!
Old 10-09-2012, 10:59 AM   #131
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
What about a "ghost" TV? (1939 Pontiac)
Ghost Pontiac « Wood,Wires, + Wheels
1982 34' Limited
WBCCI #3321
TAC #GA-24
Old 10-09-2012, 11:04 AM   #132
Aluminated
1987 29' Airstream 290
El Cajon , California
Images: 14
I've heard of the Zephyer Pro-40 polish. I think it's used primarily for maintenance of the shine, once you've already polished the AS and the 'hard' work is done. On another note has anyone ever found a spray on paint remover that will work with aluminum? I'm still trying to get the clear coat off and the citrus stripper is painfully slow!
ericjan2 is offline   Reply With Quote
Old 10-09-2012, 11:46 AM   #133
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
Several years ago I used a Klean Strip product called Auto Strip, it says it removes all finishes and I agree. Make sure you tape off all surfaces where you don't want to remove the finish. I sprayed it on two to three feet sections at a time let it sit and the clear coat bubbles up, I removed what I could with a soft plastic scraper, sprayed a second time and the remainder came off. I used it on the surface between the mid stripe and the top stripe on my motorhome. I purchased it at Wallmart. The manufacturer's website is www.kleanstripauto.com.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 10-09-2012, 12:20 PM   #134
1978 25' Tradewind
1979 28' Airstream Excella 28
Mountain Home , Arkansas
I just finished replacing the rear quarter panel on my 78 AS. The part came from Airstream and has a coating on it that won't come off. I took a piece to our local Auto Paint supply store and they tried their most powerfull stripper on it and it would not budge. What stripper will remove the outer coating on a brand new Airstream panel?
Ed Normandy
ednormandy is offline   Reply With Quote
Old 10-15-2012, 12:06 AM   #135
Ed Normandy
No idea Ed...
Open a fresh post in this section, otherwise it will just get buried...
Old 10-15-2012, 12:15 AM   #136
Alrighty then...
Moving forward when I get time...
Need to get all the roof and bits sealed ready for the winter and rain..
Wanted to polish the forward end next time the ladder is out, so needed to remove all the stuff on that segment...
Horns are off, and their brackets are next.
I pulled off the upper marker lamps, and castings...
Lamps will be replaced as they are toast... sun aged and brittle... some just palin disintegrated on removal.
Once they were all gone, I sealed the wire and screw holes with some foil tape because we were expecting rain this week...
So this weekend I had some "Bench Work" to do!
Old 10-15-2012, 12:24 AM   #137
They are pretty crusty up close..
Stripped the old sealant bead off with a putty knife.
I set to them with the trusty Dremel Multi-Max with a 150 grit pad.
Just sanding them out one by one...
Last one...
Done..
Old 10-15-2012, 12:28 AM   #138
One polished...
Done on my HF bench grinder/buffer, with Black bar..
Then they all got kinda shiny...
Not perfect, but better than before... Castings just done shine up like the sheet!
Old 10-15-2012, 05:18 AM   #139
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Looking good!
desertair27 is offline   Reply With Quote
Old 10-20-2012, 02:26 PM   #140
Prepping for the front cap polish...
I am gonna try something crazy this week... some homebrew polish...
Strip & Polish 89 Excella 32' cjack99 Cleaning, Stripping & Polishing 14 04-06-2012 10:03 AM
Motorhome versus Trailer Member Search crzycpa Our Community 1 08-23-2011 12:30 PM
Seal or Polish first JIMandPJ Ribs, Skins & Rivets 4 03-14-2011 11:58 PM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
