Old 08-20-2010, 02:26 PM   #1
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
Spot Stripping End Caps Saving Coating on Remainder
Although I will likely haul the trailer up the road to Hanover, PA. and have 1st Impressions strip and polish it (see Frank's Blog Posting... Frank's Trailer Works Blog: Another 10 at 5 ) but, I may take a shot at the end caps in the time being.
Most of my trailer is still in pretty good shape, but the end caps bug me every time I look at them. I thought about perhaps going "two tone" for a while (strip the end caps, leave the rest intact). My main question is: how hard is it to spot strip, in particular, can you remove the stripper without water, thereby hopefully not stripping the area below the end caps? Can you wipe it off with paper or disposable towels?
FYI: One of my problems is that I live in a downtown "urban" area /historic district. I am lucky that I have a nice big area behind my house that I rent for parking the AS etc., however I think the folks would frown on me washing stripper off on to their property, biodegradable or not. The area that I park on is gravel so it is not like I can sweep it up.
Another question, when you strip/polish the end caps, do you remove the "Airstream" decals or do you work around them. It would seem that it would be easier to remove them and then replace them (if one desires, and I think I would) with new ones.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 08-20-2010, 03:14 PM   #2
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
I spot stripped my Sovereign (roof). I masked the top of the window with blue tape and newspaper, then I taped drop cloths (old sheets) to the newspaper to prevent the stripper or the residue clearcoat etc from falling on the sides of the AS. This allowed me to strip the roof where the clearcoat was here and there peeling. I must say as a temp fix, it came out not half bad. There is obviously a line that shows were the tape was but much better than the patchy clearcoat. Just be creative and you can accomplish a lot with a littler. Good luck!!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 08-20-2010, 03:51 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
WHY?
If your going to take it in for a strip/polish in a few weeks....why are you even thinking of this end cap deal. All I see is a mess, complicating the coming polish job...plus, if you have never used strippers .....it takes a lot of prep and cautions.
Old 08-20-2010, 06:16 PM   #4
Soyboy's Avatar
1999 28' Excella
Images: 44
Melody, thanks but I likely won't get it stripped until next year (if I keep my job!). Gotta save up some bucks. In the meantime, I just wanted to get some of the splotchy areas looking a bit better in the meantime. Heck you should know that guys are not rational about this stuff (well maybe 2airishuman is ).
Airdreamer, did you rinse or wipe off the stripper?
1999 28' Safari
TAC MD-6
AIR 4534
Old 08-20-2010, 07:12 PM   #5
Baltimore , Maryland
I think if you are going to strip it, you should just do the whole thing at once. I think however 1999 is not Alclad aluminum. That might make polishing an issue.
Can you buy new end caps? Mr & Mrs S General Interior Topics 8 05-15-2010 08:26 PM
End caps WILDRTEXAS Interior Restoration Forum 16 02-17-2010 11:47 AM
Interior End Caps bill.johnson Floor Finishes 4 09-26-2009 10:08 PM
stripping interior end caps goransons Upholstery, Blinds, Walls & Interior Finishes 6 12-21-2008 08:46 PM
Stripping the Interior End Caps--Am I Nuts? ironfem200 General Interior Topics 2 01-29-2006 04:07 PM
