Old 05-25-2007, 06:36 PM   #1
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Speaking of polishing ...
I was wonder who would wash and polish my trailer a detail shop a Airstream dealer?. ALSO how much do you think it would run?
I wish I had more time OR I would do it but I have so much do on my trailer I am looking late fall maybe having it back together.
Mrcrowley is offline   Reply With Quote
Old 05-25-2007, 09:32 PM   #2
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Have you "Search"ed Polishing?
Try the search option.
I have heard $100-125 per foot including the tongue. Then you have the option of coating the skin with something to keep the polish up. $$$$$
Consider white paint on the top panel for heat reflection. More Search.
Some ambitious people buy a polisher and go for it.
This is a good place to post your ideas get feedback.
R
"Talk is cheap, Airstreams are expensive," Wally Byam.
fastrob is offline   Reply With Quote
Old 05-26-2007, 06:09 AM   #3
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
If you don't feel like searching using the search button, this forum has a sub-forum on the topic of "Cleaning and Polishing" your trailer. You can find the sub-forum at this link: http://www.airforums.com/forums/f441/
Good luck with it! We have actually done our own polishing on our Bambi II and it took us about 60 hours of work to work through two of three passes we need to do. See the "before" and "after" photo below. The "after" photo is after the first cut. The first cut is the most work!
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 05-26-2007, 07:45 AM   #4
1977 31' Sovereign
Images: 33
Woaaaa hmmmm let seeee..
R
31 foot sovereign x $125.00 that would be GULP $3800.00 hmmmm think ill be doing it myself me and two strong teenagers . wonder if they rent the equitment at say taylor rental or a tool rental place...
Old 05-26-2007, 08:17 AM   #5
bevman's Avatar
1958 22' Flying Cloud
Saint Helena , California
I bought a Buffalo variable speed polisher (new) on EBAY for $51. The problem with renting is that you will need it for quite a long time.
bevman is offline   Reply With Quote
Old 05-26-2007, 09:09 AM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
And then there's annual touch-ups.
5 meter Langford Nahanni
Old 05-26-2007, 09:10 AM   #7
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Coating?
Nice work. Did you apply a finish to prevent the shine from wearing off?
R
Old 05-26-2007, 10:33 AM   #8
1977 31' Sovereign
Images: 33
I have a car buffer only used once...
Ill look and see what kind maybe I can use that...
Old 05-26-2007, 12:59 PM   #9
toastie's Avatar
1955 22' Safari
Great Lake State , .
Better to buy for future maintenance, don't even attempt without scaffolding, my guess is $1000.00 for needed material and equipment and you provide the labor......check it out
Home
toastie is offline   Reply With Quote
Old 05-26-2007, 11:13 PM   #10
yukionna's Avatar
Massachusetts
Images: 18
No, we don't apply any finish. We just touch it up with a light buffing annually, as needed.
WBCCI Region One
Old 05-27-2007, 06:55 AM   #11
Pacerized's Avatar
1981 25' Excella II
Dillon , Colorado
Images: 11
Home
I'm a little taller then most, but I didn't find a need for scaffolding. I have the folding ladder the you can make into a scaffold, but found it easier just to use a 2 step stool to reach the high areas. I didn't do the top of my roof however, just as high as could be seen from the ground. I bought my cyclo used for $100 with some pads, a gallon of liquid gold, polish, and a few extra pads. Less then $300 altogether.
Charlie
Pacerized is offline   Reply With Quote
Old 05-27-2007, 07:23 AM   #12
yukionna's Avatar
Massachusetts
Images: 18
Charlie
We are trying to figure out how to get to our roof to polish it. We will probably rig up some kind of scaffolding.
I know some folks paint the top panel white but I personally would never paint the top of a vintage trailer. I like to see the "shine" all around!
WBCCI Region One
Old 05-27-2007, 08:04 AM   #13
toastie's Avatar
1955 22' Safari
Charlie
$200.00 scaffolding
$270.00 cyclo polisher
$200.00 nuvite
$170.00 compounding drill
$48.00 cyclo wraps
$15.00 microfiber
$25.00 pad kit
$48.00 compounding kit
$35.00 small compounding kit
$26.00 gel gloss
Total $1037.00
Most of the stuff was bought at Home
Old 05-27-2007, 11:28 AM   #14
toastie's Avatar
1955 22' Safari
Forgot, another must, "The California Water Blade" after a hard rain ,can remove those water drop from the Caravel in less than 3 minutes, completely dried in 5 minutes with one small cloth.
$20.00 can be bought at you local auto zone, and other places
Polishing...approx cost? Drew Cleaning, Stripping & Polishing 10 03-31-2014 10:37 PM
Polishing Again davidz71 Cleaning, Stripping & Polishing 16 11-17-2005 05:40 PM
What Type of Polishing Pad to Use? 68 Suburban Cleaning, Stripping & Polishing 0 10-22-2002 02:28 PM
Anyone else polishing? 64GT Cleaning, Stripping & Polishing 24 08-08-2002 09:19 AM
Polishing questions Charcigar Cleaning, Stripping & Polishing 0 02-27-2002 07:21 PM
