Old 10-13-2013, 05:32 PM   #15
KAYAKAMPERS's Avatar
1966 26' Overlander
Stone Mountain , Georgia
I have seen the '89-29' and can attest to its shine. Our '66 Overlander has had male baldness for many years before we owned it. It was at the grey corrosion point, so using White Diamond polish was a two coat ( minimum ) job. Like Rob, I am not really ready or want a highly polished trailer, but the polished areas above the clear coat now has more shine that the clear coat areas! I will do the citrastrip eventually, but since it is all protected again, I am not in a hurry for that job.
_______________________________
Beth Wallace & Chris Sanor
1966 26' Overlander International
Towed by 2016 Ford F-150
Tin Can Tourist
TAC #GA-27
AIR #34930
KAYAKAMPERS is offline   Reply With Quote
Old 10-13-2013, 05:50 PM   #16
JT
El Paso , Texas
If you have a rock guard over the front window mask it off or remove it because the stripper will eat into it. I had to replace mine after using stripper
jimbob79 is offline   Reply With Quote
Old 10-13-2013, 08:25 PM   #17
Hoobiedoobie's Avatar
1987 25' Sovereign
Chilhowie , Virginia
Good to know. Thanks!!
Hoobiedoobie is offline   Reply With Quote
Old 10-13-2013, 08:55 PM   #18
Originally Posted by Hoobiedoobie View Post
Re there any solutions this fading, pitting, top that are fairly reasonable? The rest of it is in pretty good shape, a bit of cleaning and polishing I guess. I like the look of the slightly dull color. 1987 sovereign.
Deb
There are two solutions.
The first is the expensive one.
Refinish.
The second one is by far the cheapest one.
Wear dark sunglasses, in fact "very dark" sun glasses.
What you can't see, will never bother you.
Old 10-14-2013, 10:54 AM   #19
1987 25' Sovereign
Ha Ha Andy!! It's going to be a lot of work so i'm almost temped to grab some "cheap sunglasses!"
Old 10-14-2013, 10:57 AM   #20
1987 25' Sovereign
Kayakampers, so you just used the polish on the faded section?? That would be a great temporary fix! Then we can do the "big" job next fall! Did you do it by hand or with a buffer? Also, where did you purchase the polish?
I LOVE THIS FORUM!
Deb
