Old 08-28-2010, 04:39 PM   #1
1989 34.5' Airstream 345
Dimmitt , Texas
soda blasting off the clearcoat
I have a 345LE Motorhome and was thinking of soda blasting the clearcoat off before polishing. Just wondering if anyone has done this. Looks easier than chemical stripping.
Max
1989 Airstream 345LE
maxr is offline   Reply With Quote
Old 08-28-2010, 07:58 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hi Max. Here are a couple useful threads:
You would open seams and make your Airstream a sieve if you used any chemical strippers. So soda or other such products seem very possible. Just stay very light on the touch when passing across aluminum.
I'm sure you could drum up very good information if you sought out opinions from your local light aircraft owners or maintenance facilities. They are dealing with the same issues!
Please follow through your posts in this thread and include us in any info or pictures you might generate in this process.
5 meter Langford Nahanni
Blasting Frame bwaysteve Repairing/Replacing Floor &/or Frame 14 03-15-2010 08:52 PM
Pressure, steam or soda panel cleaning? truckasaurus Ribs, Skins & Rivets 5 03-14-2009 10:12 AM
Soda Blasting Test Chopper All Argosy Trailers 9 10-02-2006 10:40 PM
Blasting the Screen Door Chopper Doors & Locks 1 09-19-2006 10:04 AM
Media Blasting Exterior fangthorpe Airstream Motorhome Forums 3 11-23-2003 05:47 PM
