Old 01-26-2011, 12:42 PM   #1
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Soda Blasting
Has anyone tried soda blasting window trim or any of those small hard to get to places? Thanks,Dave
easyride is offline   Reply With Quote
Old 01-26-2011, 02:19 PM   #2
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
Send a message via Yahoo to Rollerboy
to remove paint or for what purpose?
Rollerboy is offline   Reply With Quote
Old 01-26-2011, 07:33 PM   #3
2008 27' Classic FB
Plymouth , Massachusetts
I plan to
On another thread someone said it leaves a satin finish and is harder to polish. That's ok w/me as I prefer a satin finish on the inside. I've seen several youtube soda blasting videos and it seems easy enough. Harbor Freight has cheap equipment or you can rent. The other poster (can't remember who) said he went through a lot of the media so you may want to try for a more heavy duty media initially. To me, it beats the chemicals.
Don...
2008 27FB Classic
My Airplane Construction Website:
http://www.donsbushcaddy.com
NTRPRZ is offline   Reply With Quote
Old 01-26-2011, 07:52 PM   #4
Ottawa , ON
Here's the only thread I could find on it:
http://www.airforums.com/forums/f227...est-26533.html
Old 01-26-2011, 08:00 PM   #5
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Steve (soldiermedic) has some stuff on soda blasting here http://www.airforums.com/forums/f71/...-44194-18.html.
Vaughan
Old 01-26-2011, 09:13 PM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
Take it easy & don't build up any heat. I've warped and pitted aluminum sheet with the perhaps somewhat coarser walnut shell granule blasting.
http://www.airforums.com/forums/f441...oval-6285.html
http://www.airforums.com/forums/f227...est-26533.html (oops, thanks Aage)
http://www.airforums.com/forums/f441...oat-68759.html
5 meter Langford Nahanni
Old 01-27-2011, 06:04 AM   #7
easyride's Avatar
1977 27' Overlander
Naples , Florida
Thanks on the input,I plan on using the soda,which is the least aggressive of any of the medias.I will mask off around the windows,and blast the frames to clean them up.
As far as tongue,I will use walnut to blast it. Thanks,Dave
Old 01-27-2011, 06:58 AM   #8
Images: 59
I think corn cob is less agressive than soda. It might not get enough material removal though.
If you want to try something no one else has tried use yellow corn cones. It should be slightly harder than corn cobs. Corn cones are very fine corn grits.
soda blasting, cleaning
