Old 08-07-2011, 11:05 AM   #1
bluemoontwo's Avatar
1958 18' "Footer"
San Luis Obispo , California
So it begins....
Hi all,
We really want the polished look of our '58 AS so we've read many (many!) forums about polishing our Airstream here on the forums.
We purchased the following products for our task:
- Polishing compounder (WEN Model 945)
- Compounding Pads (Long Nap)
- Nuvite polishing products (G6 and S)
We did our first pass this morning with the Wen, compounding pads and G6. When we wiped away any residue we noticed a ton of little "marks" on the aluminum (picture below):
We're not sure what these are. Can someone help us determine if we need to use a different grade of polish or pad to remove these?
Thanks in advance for all of your help!
bluemoontwo is offline   Reply With Quote
Old 08-09-2011, 07:35 PM   #2
1958 18' "Footer"
I don't think our image uploaded last time. I'll try it again...
Forum Thread: The Chronicles of the Shiny Tiny
Happy to finally be part of the (t)in crowd!
Old 08-09-2011, 08:55 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
What you have is corrosion....not bad, but there just the same. Your WEN is a car polisher. Nice...but won't do the job. You need something with more "oompf". I won't make a suggestion...it will just confuse you. Look under the polishing threads...I like Caswells' site and more recently Jetsco. You will need to compound...WEN wont do it. And....will need a Cyclo or similar to finish up. G6 is good...but I think C will do a better finish than the S as a final....use the S to really shine her up. Its just my opinion.
Old 08-09-2011, 11:49 PM   #4
1958 18' "Footer"
Thanks for your response! We appreciate the help. We would love to hear your recommendation even if it's confusing. We want to learn all about this process and everyone's opinion.
Thanks again!
'59 Pacer Shell-On Renovation worldinchaos 1959 Pacer 388 10-24-2014 11:03 AM
The Buddha Baby A Restoration wasagachris 1960 - 1964 Sovereign 136 06-30-2012 08:56 AM
The conversion begins - with pics robwok 1960 - 1964 Overlander 6 02-24-2011 11:38 AM
Ah Yes! The Adventure begins. johnwatkins Member Introductions 3 01-15-2011 07:17 AM
