Old 04-26-2010, 08:41 PM   #1
1966 24' Tradewind
portland , Oregon
Skin question
Hello,
I replaced a couple of outside skin pieces with new .040 aluminum 50-52. Now the replaced area doesn't look like the old skin. I heard that the original skin was .035 aircraft grade aluminum. I don't think you can buy that anymore. does anyone gone through the same thing? would polishing do thr trick? any suggestions
steverad is offline   Reply With Quote
Old 04-26-2010, 09:18 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I believe the outer skin is 2024 T3 0.032"
It is still being made.
Richard
Old 04-26-2010, 09:30 PM   #3
Absolutely correct.
Old 04-26-2010, 09:40 PM   #4
1966 24' Tradewind
portland , Oregon
Thanks Richard,
It is too late, I have already replaced several pieces. The bozo (butch Walter) mis-informed me. Oh well, what should I do to make the replaced area look like the rest?
Steve
Old 04-26-2010, 09:41 PM   #5
Originally Posted by steverad View Post
Thanks Richard,
Steve
Steve.
To make the new match the old metal, you will need to start all over again.
Old 04-27-2010, 02:13 AM   #6
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
It should be stated, as many already know... that the thickness is not the issue it the type of aluminum.... "Alclad" The alloy that has the protective coating on the outside surface is the correct aluminum for your year of trailer... 2024-T3 .032 is the spec .... However, I like others are using .040 (same thickness of todays' Airstreams) on belly panes and other parts of the trailer just fine! It should also be noted that Airstream switched to 6061-T6 .032 in the early 70's due to cost! SO the real question becomes how shinny do you really want your trailer because both will polish the "Alclad will just be "more shinny" ...
Now to your uses of the 50-52 would in my mind be more about strength than looks... It is my understanding (and not fully sure so I hope others will chime in) that the 50-52 due to the fact it is not tempered should not be used because it is too soft and not what most would call structural strength aluminum! So should you replace the panels that you have replaced... I would have to state yes, due more on the side of strength than looks!!!
Todd...
P.S. I can provide a source for the best price of 2024-T3 .032 and .040 if you so desire that information...
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 04-27-2010, 04:41 AM   #7
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Alclad, that was used in the early Airstream trailers, is actually a laminate. The alloy in the middle is 2024. That is an alloy with copper in it and has poor corrosion resistance, but can be heat treated to obtain a high strength. To make is suitable for airplanes, they coated it with pure aluminum, which has poor strength but excellent corrosion resistance. Therefore; the name : AL CLAD, aluminum coated. This material is still available from Aircraft repair supply houses.
Old 04-27-2010, 04:58 AM   #8
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Aircraft Spruce has as much 2024 as your checkbook can stand. Here is the link to the web page for what you needed. 2024T3 ALCLAD ALUMINUM from Aircraft Spruce
Old 04-27-2010, 09:15 AM   #9
1966 24' Tradewind
portland , Oregon
Thank you all for the great information. My conclusion form reading these posts is that either I live with the look of it or replace all of the new pieces. (6 pieces) OUCH
Have a great day
Steve
Old 04-27-2010, 11:29 AM   #10
lynn's Avatar
1960’s switched to Alcoa for the Aluminum material. Alcoa-Aluminum Alclad sheet 2024-T3 .032
1998 -200….Alcoa Bright Versatrim leveled sheet 3004-H18 side and window sheet .040
lynn is offline   Reply With Quote
Old 04-27-2010, 06:56 PM   #11
Kevin245's Avatar
5052 falls into the Non-Heat–Treatable (NHT) family of alloys along with 1XXX, 3XXX, and 4XXX. While 5052 can't be strengthened by heat treatment it can be strengthened by cold working which gives it an F temper designation. 5052 can be purchased in several other tempers as well. The main alloy in 5052 is magnesium which helps give it strength, it also has good corrosion resistance and is stronger than 1XXX and 3XXX alloys. The only way to really strengthen though is to bend, brake, or otherwise form it.
2024 is in the Heat-Treatable (HT) family along with 6XXX, and 7XXX series alloys.
2024 comes in an assortment of tempers as well (T4, T6, etc.). T3 is an alclad sheet and commonly referred to as aircraft alloy because of its yield strength and fatigue resistance and has a yield strength in the 50ksi range, where as 5052 yields in 24 ksi range.
While 5052 isn't the strongest material, its not the end of the world in my book.
Best of luck,
Kevin
Eleanor Roosevelt
Old 11-21-2010, 07:55 AM   #12
DAO
2017 25' Flying Cloud
Angleton , Texas
Todd...
Can you provide a source for 0.040" sheets?
doutterson is offline   Reply With Quote
Old 11-21-2010, 09:07 AM   #13
What size sheets?
Old 11-21-2010, 12:09 PM   #14
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
Aluminum Sheets,2024T3,6061T6,3003H14,5052H32
These guys were excellent to deal with :-)
truckasaurus is offline   Reply With Quote
Second skin ltenbrink Ribs, Skins & Rivets 5 01-25-2010 07:11 PM
aluminum skin question art Clearcoat, Exterior Paint & Trim 8 09-08-2009 09:38 AM
A question on underbelly skin and its gas lines. soldiermedic Belly Pans & Banana Wraps 12 11-23-2006 03:34 PM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 04:50 PM
'65 OL skin ronmcor 1966 Overlander 1 11-11-2004 06:51 PM
