Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 09-20-2016, 05:26 PM   #1
LFC
Memphis , Tennessee
Should I try and clean or trash ?
I just bought a set of rims and tires from a member here...he mentioned in his add that they had some filiform corrosion.
He delivered them across country and when I saw them I was somewhat let down but took them because I just didn't feel right after the fellow toted them 600 miles.
I've owned two Airtreams a 1999 and a 2000 and honestly didn't know what filiform corrosion was and when I saw it today I thought it could easily be removed. Boy was I wrong SOS and Brillo pads won't even touch it.
My main concern is now I own a 1977 Avion with no signs of any corrosion and I 'm worried if I put these wheels on my trailer that this hideous corrosion could spread to my Avion.
Should I try and clean these up or just throw the rims away and chalk this up to experience ?
LFC is offline   Reply With Quote
Old 09-20-2016, 05:35 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I plan on soda blasting mine. They are looking pretty nasty with the clear coat peeling off. Depending on how they come out I may leave them as is or polish. I have a friend with an SOB that soda blasted his. They look really good as is and no more peeling finish or corrosion. Soda blast will not remove any metal only the corrosion and clear coat.
MICHAEL
Old 09-21-2016, 10:22 AM   #3
LFC
Memphis , Tennessee
I tried some Aluminum Bright from Napa Auto Parts it seemed to help a little...I also found a small soda blaster on eBay I guess that's next.
http://www.ebay.com/itm/251615101183...84.m1438.l2649
And I came up with another cheap one.
http://www.eastwood.com/soda-blast-intro-kit-53591.html
Old 09-22-2016, 05:34 AM   #4
AWCHIEF's Avatar
Images: 33
I have a couple different set ups from HarborFreight. A cabinet and seperate gun for larger parts such as the wheels we are discussing. HF normaly has them on sale plus using the common 20% off coupons makes for a good deal.
MICHAEL
Old 09-22-2016, 06:39 AM   #5
LFC
Memphis , Tennessee
I'm not sure if a regular sand blaster will work for soda blasting ?
The soda blaster I saw at Harbor Freight was about a 100 bucks.
Old 09-22-2016, 06:46 AM   #6
Mantua , Ohio
It won't spread, it's an AS thing.
Old 09-22-2016, 06:52 AM   #7
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario Canada
Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
Check around your area and see if the cost of professional refinishing is a good option. We have a guy in London Ont. that will do it for around $100 per wheel, strip and powder coat, in many colors or clear. Tire and stem removal is required however.
Filliform corrosion will not spread to the trailer from the wheels.
TRIPPPIN is offline   Reply With Quote
Old 09-22-2016, 06:57 AM   #8
AWCHIEF's Avatar
Images: 33
It will. I use both my blasters for sand and soda.
MICHAEL
Old 09-22-2016, 07:00 AM   #9
LFC
Memphis , Tennessee
That's good to know, thanks for the soda blasting tip I'd never heard of it.
Old 09-22-2016, 07:21 AM   #10
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I bought a set of aluminum wheels some years ago. They were pretty rough. I sanded them to clean them up, painted with silver aluminum paint. ( Most wheels are painted. Clear doesn't stick to most aluminum very well) and clear coated. Looked good and held up well for a couple of years and went with the trailer when it was sold. The key here is the clear coat. I have a friend with a body shop and he did mine. Spray can clear may not hold up very well.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 09-22-2016, 07:58 AM   #11
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
I read somewhere, a car board, maybe, about using oven cleaner to strip and then polishing. As I recall, the oven cleaner really darkened the wheels but they polished up good. Try anything on the back side first. I used Jasco Premium Paint and Epoxy Stripper from Lowes to strip powder coat off of a grill mounting rail. It took two applications, covering with plastic wrap to stop evaporation but it didn't attack the aluminum at all. Citristrip should work as well, it takes clearcoat off of trailers. The thread I read used a Griots Garage cone-shaped polisher in a rotary tool after stripping with oven cleaner.
Al
Old 09-22-2016, 11:27 AM   #12
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I sold my wheels with slight corrosion to a nice man in Indiana who was restoring a 70's Airstream.
I cleaned them as best I could before I sent them to him.
3 out of 4 looked nearly new after cleaning.
1 had some stubborn spots I could not get off, but still looked nice at 20' away.
He was happy.
I don't think the corrosion will leave the wheels and get on your trailer...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-22-2016, 12:04 PM   #13
Don McKelvay
Don McKelvay's Avatar
1994 34' Limited
London , Ontario
Hi, I would appreciate the name, address and tel of the guy please.
Don
________________
Don McKelvay
WBCCI #205
AIR #42
1994 34' Limited
2004 GMC 2500 HD
Hensley Hitch
Don McKelvay is offline   Reply With Quote
Old 09-22-2016, 02:14 PM   #14
1973 31' Sovereign
Middletown , California
The corrosion won't spread off the wheels but it might spread under the paint if you just paint over the wheels. You probably have to get an anti-corrosion chemical under the paint to stop filiform. Or you could just paint the wheels with aluminum paint and not worry about it, it would take decades to cause a structural problem with the wheels. The best thing would be blasting then polishing the rims but that requires some power tools so you don't wear out your fingers!
ijustlee is offline   Reply With Quote
Old 09-22-2016, 05:37 PM   #15
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
New wheels are only $110 each, to your door, you can't spend much for used ones.... It isn't economical....
Stash and Trash kcbwil 2007 Safari SE 3 07-25-2011 04:58 AM
How should we try to fix a small, shallow dent myboyburt Ribs, Skins & Rivets 3 07-07-2009 06:58 PM
Should I trash my Sears floor jack? Kistler Our Community 35 08-05-2007 06:28 PM
Beware, trash till Off Topic Forum 0 11-29-2004 08:32 PM
Island Trash Revisited jaco Off Topic Forum 1 04-30-2004 10:01 AM
