Old 03-27-2013, 12:19 PM   #1
wheelerimage's Avatar
1965 20' Globetrotter
1955 22' Safari
Butte , Montana
Images: 8
Sewing Caswell's Polishing Wheels
I purchased two 1 inch thick polishing wheels from Caswells. I want to sew them together to make a 2 inch thick wheel. I have taken them to 4 different sewing places, including a shoe repair and upholstery shop and a industrial sewing shop. Nobody can sew them together.
Question 1.
Do I even need to attach them together? Maybe if I just tighten the bolt in the polisher that might be enough pressure.
Question 2.
What if I epoxy them together or bolt them together?
Question 3.
Any recommendation on how to sew them together?
Thanks!
wheelerimage is offline   Reply With Quote
Old 03-27-2013, 12:26 PM   #2
Central , Mississippi
I have used option #1 and it worked fine.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 03-27-2013, 12:31 PM   #3
1955 22' Safari
Butte , Montana
Images: 8
Thanks HiHo!
It might be warm enough to polish up here in Montana this weekend. So I guess I'm all set.
You're Overlander is looking Awesome, by the way!
Old 03-27-2013, 12:50 PM   #4
Jestcoproducts.com has extra thick wheels 6" 8" and 10". 3 inch's thick.
I find these to be great for large areas
0557 is offline   Reply With Quote
Old 03-27-2013, 01:37 PM   #5
Originally Posted by wheelerimage View Post
Thanks HiHo!
I'm hoping it will dry up here enough to polish before it's too hot in a few weeks!
Old 03-27-2013, 01:41 PM   #6
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Question 1.
No.
Just tighten the bolt, that's all we did.
Question 2.
DON'T DO IT! The epoxy will scratch your trailer.
Question 3.
Not needed - refer to Q#1.
Shari
Old 03-31-2013, 06:57 PM   #7
1955 22' Safari
Butte , Montana
Images: 8
I started compounding with the brown bar . It took five hours to do the area behind the door. It's a lot harder to do the 55 it was the 65. I might try to switch to the black bar and see if that helps
Old 03-31-2013, 07:13 PM   #8
InsideOut's Avatar
1956 22' Safari
Images: 108
10 more years of oxidation will do that! Looking good though!
Shari
Old 03-31-2013, 07:21 PM   #9
1955 22' Safari
Butte , Montana
Images: 8
Thanks Shari. Good from far, far from good! Ha ha
Old 03-31-2013, 08:49 PM   #10
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Be carefull with the black bar, you can go through the Alclad layer with it, if used to much.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 03-31-2013, 09:05 PM   #11
1955 22' Safari
Butte , Montana
Images: 8
Ok. Thanks. I go easy with black. I'm surprised how long it takes to cut through with brown
Old 04-01-2013, 03:38 AM   #12
Baltimore , Maryland
People will cringe....
Have you considered a flashing agent(acid)? This type of product is used by just about all of the professional polishing services as a first step. It will remove a vast amount oxidation with little effort at all. It is very important to neutralize the acid after it has done it's thing. I mix a large box of baking soda in 2 gallons of water and spray it on twice to be sure that it is all neutralized. The neutralizing instructions do not appear on the label. It is a step I introduced in my shop to be sure the acid was not going to remain behind the rivet heads and seams.
Old 04-01-2013, 03:55 AM   #13
... and ditto what Shacksman said about the black. I will throw in that it is important to keep the wheel moving. It is possible to heat a small spot and then stretch the metal there too.
Old 04-01-2013, 08:11 AM   #14
1955 22' Safari
Butte , Montana
Images: 8
Thanks Frank,
I think I will look into a flashing agent. I will go to the auto parts store today. What is a brand that is good?
The skin is rougher than I thought it was going to be. Its covered with these spots that are very difficult to polish out. I will try to get a picture with mu iphone.
