Old 06-07-2011, 11:40 AM   #1
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Scotchbright and alclad
I am planning to polish, will a scotchbright ruin the alclad if I use it to remove filform?
Darkspeed is offline   Reply With Quote
Old 06-07-2011, 11:50 AM   #2
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
No, it won't. I used automotive sandpaper & it was fine.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 06-07-2011, 12:17 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
IMO, you would be better off trying milder "compound" abrasives first. In the long run, the more scratches you put in your trailer with scotchbrite, sandpaper or emery cloths the more you will have to remove in the later phases of polishing to acheive that mirror shine you will be striving for. The Alclad layer is very thin - if you go through it with harsh abrasives or compounds, you will have a splotchy "grey shadow" effect when you are done where the Alclad was burned through. It'll still polish, but it will oxidize much more quickly than the areas that you didn't burn through - it's not pretty and the only way to "fix it" iis to replace the affected panels.
Shari
Old 06-07-2011, 12:28 PM   #4
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Google 'Gravel in a bottle' by 3M ...it is a creamy 14 oz bottle, and you can hand do it.
Cost about fourteen to fifteen dollars to ship...I got mine through R&S automotive online. Mind you, the title is aggressive sounding but they are featuring the grit in it to last longer than most compounds. whicjh is true.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 06-07-2011, 02:29 PM   #5
Darkspeed's Avatar
1972 31' Sovereign
Ok just ordered a gallon
Any good source for a 5/8 mandrel to mount cloth wheels to a variable speed grinder?
Are the hook loop pads better ?
Old 06-07-2011, 02:45 PM   #6
altnbndr's Avatar
1967 17' Caravel
1968 22' Safari
Sacramento , California
Images: 11
grinder adapter
I got mine from jestco.
altnbndr is offline   Reply With Quote
Old 06-07-2011, 04:13 PM   #7
Darkspeed's Avatar
1972 31' Sovereign
Thanks just got one ordered and some 8" cloth wheels as well
Old 06-12-2011, 03:57 PM   #8
Darkspeed's Avatar
1972 31' Sovereign
So I'm using the 3m and a 10" wheel but I am getting highly polished filform .
What am I doing wrong do I need a more aggressive polish medium?
Old 06-12-2011, 04:03 PM   #9
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Did you remove the clearcoat first?
Bill
Just my personal opinion
Old 06-12-2011, 04:42 PM   #10
Darkspeed's Avatar
1972 31' Sovereign
Yes did two passes with stripper.
I'm just wondering what is SOP for removing filform during polishing.
The 3m stuff is good but it does not seem very aggressive
Old 06-12-2011, 04:52 PM   #11
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
My understanding of Alclad, aluminum clad alloy.
Is there not a concern of polishing thru the clad?
Filiform can be pretty deep.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 06-12-2011, 04:52 PM   #12
Darkspeed's Avatar
1972 31' Sovereign
I could be more aggressive with it I just have this phobia of burning through or warping with heat. Am I being a wus?
Old 06-12-2011, 05:21 PM   #13
Becky B.'s Avatar
1964 17' Bambi II
I'd like to know how many people actually have "burned through" their alclad. I've polished two AS's--one 27 ft, one 31 ft. and had no issues. I used varying degrees of automotive sandpaper on the endcaps of my '86 to achieve a mirror finish & had no problems. After sandpaper, I went to rouge bars & then to Nuvite C & S for final finish. Yes, filiform can be removed with sandpaper. Start with 2000 & see what it does. After using it, use steps back down to get rid of the scratches your sandpaper puts in the aluminum. Are you being a "wus"? I dunno! How about a survey of how many people have actually burned through the alclad & that might help you decide what to do!
Becky
1964 Bambi II
1988 Avion 32S
Old 06-12-2011, 05:26 PM   #14
Darkspeed's Avatar
1972 31' Sovereign
Thank you! That's what I needed to hear I will try some 2000 and see what the results are.
