Old 05-20-2009, 05:03 PM   #1
AireHeads
AireHeads's Avatar
1965 20' Globetrotter
St. Petersburg , Florida
satin vs gloss finish
Am I the only one that doesn't want a high gloss finish? On our 1965 Globetrotter I would like a clean satin finish with a coating to protect the aluminium. Would the process be the same just stop with a coarse buffing compound before the finish?
AireHeads is offline   Reply With Quote
Old 05-20-2009, 07:03 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
If you did that, you'd probably end up with swirl marks in the aluminum.
Old 05-20-2009, 07:20 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
It almost sounds to me like you may be describing something similar to the original factory sheen finish. When I had my '64 Overlander refinished, I asked for the lower sheen original-style finish on the aluminum -- I can't tell you how it was achieved, but the Ruths at P & S Trailer Service in Helena, OH provided exactly what I wanted. A photo of my Overlander is below:
I didn't want the mirror shine as this is how I remembered the Overlander from my first camping trip in 1964 when it was new.
Kevin
Kevin D. Allen
AIR #827
Old 05-20-2009, 08:35 PM   #4
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Kevin
I'd be interested in learning how this finish is achieved.
Grant
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper (65avion.home.blog)
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 05-20-2009, 08:47 PM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
a natural look
If you strip the entire Airstream,,,well. Then use aluminum brightener, agitated with a very light 3M pad. Seal it up and put on an original Airstream clearcoat. Result will be a beautiful natural looking item.
Old 05-20-2009, 09:47 PM   #6
tallytwo1994's Avatar
tallahassee , Florida
"Aluminum Brighteners" are an acid wash. Acid etches metal and can cause problems if not neutralized quickly and completely. If you choose this method be very careful so you don't cause damage to these vulernable areas; rivits, panel seems, and window glass.
Carol
tallytwo1994 is offline   Reply With Quote
Old 05-20-2009, 11:11 PM   #7
AireHeads
AireHeads's Avatar
Yes Kevin, that is what I would prefer the the orginal sheen, and some one to do it for me.
Thanks for the info.
michael
Old 05-21-2009, 09:24 AM   #8
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I've seen trailers that were both soda blasted and walnut shell blasted. Both were very nice alternatives to the mirror polished look. I believe the walnut shell finish was done by P & S...but I'm not sure.
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
mirror finish what next? kooblekidz Cleaning, Stripping & Polishing 10 04-13-2009 08:24 PM
Name that finish! Stefrobrts Upholstery, Blinds, Walls & Interior Finishes 3 05-28-2004 12:55 AM
Metal Gloss polish & sealer LeeA Cleaning, Stripping & Polishing 15 11-26-2003 11:02 AM
New AS finish vs vintage Safari Tim Our Community 7 09-19-2003 10:42 AM
exterior finish wb13798 Airstream Motorhome Forums 8 08-18-2003 06:19 PM
