10-24-2014, 01:12 PM
2010 27' FB Classic
N/A
Sap Removal Question
I'm looking for suggestions on what product is best to remove pine tree sap on the trailer?
10-24-2014, 02:17 PM
2002 30' Classic S/O
Fleming Island
I have used denatured alcohol on clear-coated cars with good results. Quick removal and doesn't attack the clear-coat.
Al
10-24-2014, 02:46 PM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
Modern Airstreams are all clear-coated just like autos. Any bug & tar remover for auto will be safe to use on your Airstream.
There are lots of home grown solutions such as denatured alcohol, WD-40, etc...
Bob Martel
WBCCI# 5766
10-24-2014, 03:07 PM
2001 25' Safari
Ridgefield
As suggested by AnnArborBob, here's a home-grown solution. I've used Eucalyptus Oil to remove tree sap from my vehicles and it works great. You can find it in small bottles in health food stores. It removes the sap and does not harm the vehicle's finish. It's a 100% natural product and smells good too.
10-24-2014, 05:49 PM
Lynn
Beaverton
, Oregon
sap removal
Goo Gone worked for me!
10-24-2014, 05:57 PM
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
Walbernize works and shines too!
George
10-24-2014, 10:47 PM
2015 30' FB FC Bunk
Ayer
, Massachusetts
Hand sanitizer.
10-25-2014, 04:45 AM
1999 34' Excella
Hillsboro
Bluto, be careful to attack the sap only. A big rag full of solvent may not work as expected. The natural oils and alcohol sous useful. Also I have used wd40 but I put in a small container like the cap off the wd40 can and dipped with q tip. This way you can apply directly and let the solvent "work" without a lot of rubbing the surrounding Area.
Peace and Blessings..
Channing
WBCCI# 30676
10-25-2014, 06:03 AM
1964 17' Bambi II
Schererville
, Indiana
Really HOT water & a rag...it melts the sap off.
Becky
1964 Bambi II
1988 Avion 32S
10-25-2014, 07:00 AM
2014 25' Flying Cloud
Cuddebackville
, New York
Alcohol works easiest for me.
2019 Ford Expedition Platinum
10-25-2014, 07:23 AM
2012 30' Flying Cloud
Lake St Louis
, Missouri
I start with the mildest approach, soap and water, and, if not successful, work my way way up through the stronger solutions. Have found soap and water followed by polish/wax removes the sap most of the time.
Barry
WBCCI 11988
10-25-2014, 07:52 AM
ToyHouse
2014 27' FB Classic
Quesnel
, British Columbia
Margarine also can work well on tree sap for those who might be concerned about harsh solvents. Takes a little mild rubbing. Seems hard to believe I know but it works.
10-25-2014, 10:40 AM
2010 27' FB Classic
N/A
Wow, lots of great suggestions, most I wouldn't have ever thought of. I'm going to start on this mess later this coming week. Just finished up a month of travels and the trailer is covered with sap and dead bugs.
My approach will be to wash it completely then try some of the products suggested. Then wash again and wax. I know I won't get it all done in one day, this may take me a week or so. It's no fun getting old.
Thanks everyone!
10-25-2014, 01:06 PM
Overland Adventurer
2009 34' Panamerica
Telluride
Coca Cola works great! It's the phosphoric acid! Works great on bug guys that get cooked on too!
10-25-2014, 02:27 PM
2006 25' Safari
Tyler
Charcoal Lighter for Tar, Road oils, etc.
I just completed a 2400 mile run from Tyler Texas to Madison Wisconsin. Interstate systems through Arkansas, Missouri, Illinois and Wisconsin had a lot of single lane driving through MANY construction zones. Left the front of the trailer filthy with a lot of asphalt and oil products and the rock guards pretty beat up from all the loose media. I use charcoal lighter to get rid of the products they use on the roads that find there way all over the fenders and sides of my trailer and truck. Fast and easy with paper towels.
10-25-2014, 03:32 PM
Cuddebackville
, New York
I've found tar removers don't work well on sap. Alcohol does. Wet it, let it soak a bit and wipe it off.
11-28-2014, 08:25 AM
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria
, British Columbia
Rapid remover, spray on wait 60 seconds scrape off. Works for sap as well as removing most old adhesives, tar spots, some of the stickier bugs and road grime from the wheel well area.
Clear coat safe, we use it on vehicles and construction trailer all the time at my sign shop.
11-28-2014, 10:28 AM
begorragirl
2017 25' Flying Cloud
Denville
, New Jersey
My po used steel wool, took clearcoat right off, my AS has character for sure. I do not recommend it.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
11-28-2014, 10:56 AM
2011 27 FB International
Tucson
As suggested on another thread, try Pledge furniture polish. Spray it on stubborn tar and sap, let it stand for 60 seconds and wipe it off with soft cotton rags. Sap is important to remove fairly quickly - let it age and it is what we call varnish. Leaves a modicum of wax as well.
11-28-2014, 03:54 PM
flygrrl
1962 19' Globetrotter
Winchester
, Ontario
Butter!
Butter or margarine work quite well in a pinch. I usually get sap off my hands with butter, non-toxic and pretty innocuous.
TV: 2007 Jeep GC Laredo diesel
Toy: 1995 Jeep YJ
Experience is what you get from not having it when you needed it.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Tree sap removal??
wyhjr |
Cleaning, Stripping & Polishing |
32 |
03-05-2017 11:13 AM |
Tree Sap removal
falcon-N-Air |
9 |
08-24-2014 01:41 PM |
Sap removal
Luigi123 |
4 |
06-29-2014 05:51 PM |
Pine Sap Removal from Plasticoat
Gator1 |
Clearcoat, Exterior Paint & Trim |
9 |
08-07-2009 10:30 AM |
Pine Sap Removal
dwsafari |
15 |
04-10-2009 10:41 AM |
