Old 08-30-2004, 08:57 AM   #1
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Smile Run his prints, Danno...
Preparing for a trip next week to Disneyworld, I Walbernized (Walbernize is a wax for Airstreams) my Overlander for the first time since getting it this past December. Before that, it had probably been more than 20 years since anything was done to the skin.
Interesting thing is that several distinct hand smudges became apparent after the Walbernize was hand buffed off. The picture below shows the best example. In it you can see where someone layed his palm on the skin before the TV antenna was mounted. It had to have happened at the factory.
The print appears to be on the aluminum skin, and not on the clearcoat.
Although most of the clearcoat on the roof has eroded away, the clearcoat on the sides of the Overlander came out looking pretty good.
I just thought it was interesting.
Tom
Old 08-30-2004, 12:18 PM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
interesting, at least it wasn't a butt print
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 08-30-2004, 12:20 PM   #3
TomW's Avatar
1967 26' Overlander
Hmm, maybe that's what was on a rear panel
Old 08-30-2004, 03:41 PM   #4
TroutStream's Avatar
Looks good Tom!
So you just washed it and waxed it with Walbernize?
Ken
TroutStream is offline   Reply With Quote
Old 08-30-2004, 03:53 PM   #5
TomW's Avatar
1967 26' Overlander
Yes, I was a little surprised myself!
Tom
Old 08-30-2004, 04:39 PM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Just curious. Walbernize has a few different products to use, dependent upon the finish of your trailer. Which one did you use?
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-30-2004, 05:03 PM   #7
Just an old timer...
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
I am an FBI trained, court-qualified fingerprint examiner. I did a comparison based on the photo supplied. That hand print belongs to Jimmy Hoffa. OK, Tom, I have a few questions for you...
Roger
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N Sprinter & 2006 Born Free 32 RQ Kodiak Chassis
85MH325 is online now   Reply With Quote
Old 08-30-2004, 05:31 PM   #8
RivetED's Avatar
2004 25' Safari
2018 26' Flying Cloud
South West , USA
Could be 'Etching'
The acids in our skin can & do 'etch' metal. Especially non-anodized aluminum. If the print is under a clear-coat there is not much you can do without removing the coating. If it is in the coating there is a product I've just heard of called 'Nanowax' that might help. I'm going to try it later this week on some minor scratches in the clear-coat of our A/S. Walbernize will not remove the ones I'm referring to.
-Ed
RivetED is offline   Reply With Quote
Old 08-30-2004, 06:27 PM   #9
TomW's Avatar
1967 26' Overlander
Didn't know I had a choice
I used Steve's offering at Airstreamdreams.com
Tom
Old 08-30-2004, 07:28 PM   #10
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Roger
Last I heard, Jimmy Hoffa was up North, and now is in real estate...
Old 08-30-2004, 08:44 PM   #11
RivetED's Avatar
2004 25' Safari
South West , USA
And all along I thought Jimmy was now into Interstate overpass foundations! ...Is that considered real estate??
-Ed
Old 08-31-2004, 08:51 AM   #12
jcanavera's Avatar
Fenton , Missouri
Images: 143
Naw, I heard that the folks looking for the WMD in Iraq found him there......
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-31-2004, 08:56 AM   #13
jcanavera's Avatar
Fenton , Missouri
Images: 143
Tom
The folks at Walbernize told me that the Super Seal is their suggested product for the precoated Alcoa finishes or a trailer that has been recently clear coated. It has the least amount of abraisives in it. Dependent upon how much oxidation you had, there are two other grades of the Walbernize product that might just get that hand print out. You can check out the Walbernize site at www.walbernize.com
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56
Does your Argosy run on LP gas? chasgould Argosy Motorhomes 2 10-18-2004 06:54 PM
My back panel got run over!!! John Greenlee Ribs, Skins & Rivets 1 06-20-2004 11:47 AM
Power required to run A/C Ken J Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-29-2003 11:02 AM
Power seat motor won't run, any ideas rdm General Motorhome Topics 2 05-17-2003 08:04 PM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 08:40 AM
