Old 05-20-2014, 04:24 PM   #1
1994 34' Excella
Kalamazoo , Michigan
Roof paint removal...
Starting to think about refinishing our 1994 Excella 34. The white finish on the roof is pretty cruddy looking, and I have noticed that some of the restorations I have seen have the finish removed. I haven't seen anything explicitly going thru what it takes to remove it. The same stripper as the clear coat?
Thanks!
TomS is offline   Reply With Quote
Old 05-20-2014, 04:41 PM   #2
1994 30' Excella
Mississauga , Ontario
I sanded mine carefully till all the chaulky paint was gone and then painted it with Supertherm which is a heat repelling ceramic paint. My trailer is much cooler in full sun with this finish.
Al
Al and Jean
TAC ON-3
Old 05-20-2014, 08:15 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
If the roof paint isn't peeling, scuff it with 400 grit (360 will do on a white roof) and repaint.
If it is peeling or flaking, strip it chemically. Most paint will yield to stripper but not all.
But if you are going to strip the clear with chems, it will be difficult to protect the white so you might just strip it off all at the same time if it strips well.
Old 08-26-2014, 05:44 AM   #4
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
Al
Wow, sounds great! Is that the Multiceramics coating? Expensive? Did you roll it on? Use their RustVaccine to prime?
SuzyHomemakr is offline   Reply With Quote
Red numbers paint? hand paint? Zstream Clearcoat, Exterior Paint & Trim 2 10-02-2008 11:35 AM
to paint or not to paint roof Angel73 Clearcoat, Exterior Paint & Trim 18 03-31-2008 07:29 AM
To Paint or Not to Paint My Dashboard Chaplain Kent General Interior Topics 8 02-23-2006 07:41 AM
Paint stovetop with high temp paint? ironfem200 Stoves, Ovens & Microwaves 4 02-19-2006 03:47 PM
paint or not paint PeterH-Airstreamer Airstream Motorhome Forums 15 01-22-2003 09:27 AM
