Old 10-12-2013, 01:14 PM   #1
1961 24' Tradewind
1967 26' Overlander
Savannah , Georgia
Roof cement
The previous owner of my 73 Overlander used black roof cement of some sorts to patch over where the antenna was. It is not only ugly, but brittle. Any ideas of how to remove without damaging the skin underneath?
beatrix1 is offline   Reply With Quote
Old 10-12-2013, 01:59 PM   #2
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Hair dryer/heat gun and a plastic putty knife. The heat should soften it a bit, and the plastic won't damage the aluminum skin.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 10-12-2013, 04:13 PM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Plastic putty knife might not handle the heat, if you use a metal one you might be able to direct the heat at the blade and with a low angle slide it under the roof cement. Tar is flammable at high temp, might be prudent to have a fire extinguisher handy.
Old 10-12-2013, 04:56 PM   #4
r carl's Avatar
Lin , Ne
I removed some with solvent from a parts washer before. You have to take your time and let the solvent soften the tar rubbing with a solvent soaked rag. Mineral spirits may work also. It will completely remove the tar and leave you with bare aluminum. You will need lots of shop rags.
