Old 02-10-2010, 09:01 AM   #1
2005 28' International CCD
Camarillo , California
removing WBCCI number decals
any help on how to take of the number decals without hurting the clearcoat.
loft47 is offline   Reply With Quote
Old 02-10-2010, 09:19 AM   #2
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
Decals usually come off if you blast them with a hairdryer and then peel them up.
Tom
mutcth is offline   Reply With Quote
Old 02-10-2010, 09:35 AM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
You can use denatured alcohol to remove any remaining glue. Just don't rub too hard. The clear coat will start to rub off.
Michelle TAC MT-0
Sarah, Snowball
Old 02-10-2010, 09:52 AM   #4
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
The only way I found to remove the decals was Steam either with Andy's method (use a wet towel, place iron over the towel and away they go.) or I purchased one of those for sale on tv steamers worked great. But have no idea what it will do to clearcoat so caution advised.
Kevin
kevinb is offline   Reply With Quote
Old 02-10-2010, 10:50 AM   #5
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
I used Ajax and Mr. clean.then I put new numbers on and clear coated it.Looks like spick and spam
Kevin
wbcci ,#3510 NEU & 4cu http://fire1.smugmug.com
firedog is offline   Reply With Quote
Old 02-10-2010, 11:06 AM   #6
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
WD-40 should work without any ill-effects.
Pat
pmclemore is offline   Reply With Quote
Old 02-10-2010, 11:23 AM   #7
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
LIke the above mentioned...rubbing alcohol does remove and take up the glue residue left behind by the stickers...however the strength percent of it has to be as strong as they will sell over the counter and we get our higher proof of it from Walgreens. A lesser 'proof' type of it will not work so shoot for the highest number you can get. And we looked all over the place and only found the higher number at Walgreens.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 02-10-2010, 11:42 AM   #8
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
Autobody shops use a drill powered wheel-type eraser for removing decals & stripes without damaging paint & clearcoat finishes. I have used them and found the results to be good.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 02-10-2010, 11:47 AM   #9
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
I used Baby Oil... and it works. Don't ask how... it just does the job.
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
http://rvcampreview.com
dufferin is offline   Reply With Quote
Old 02-10-2010, 10:22 PM   #10
thanks to all for the quick responses! some very good ideas...
Looking for a WBCCI number kwf904 WBCCI Forum 15 03-10-2015 05:07 AM
Removing Numbers and Decals Phil Tribby Cleaning, Stripping & Polishing 32 07-24-2009 07:08 AM
Old WBCCI number balasharky WBCCI Forum 5 04-20-2009 01:57 AM
Removing AIRSTREAM Decals popeyedoyle1 Clearcoat, Exterior Paint & Trim 9 06-23-2006 01:21 PM
Number Decals Question wagsrp Airstream Motorhome Forums 7 10-11-2002 09:18 AM
