Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 06-13-2009, 09:07 AM   #1
jenner 515's Avatar
1970 25' Caravanner
Arvada , Colorado
Removing Tree Sap Oxidation?
According to the Previous Owner, he parked our 1970 Caravanner Under a tree for a number of seasons. Tree Detrius and sap landed on the skin and encouraged oxidation. (see attached). Best recommendations for cleaning prior to buffing and polishing?
I've searched here and haven't found a thread quite adressing this topic. Any help is appreciated.
ID:	82197   Click image for larger version
jenner 515 is offline   Reply With Quote
Old 06-13-2009, 11:00 AM   #2
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Is the sap still present? A solvent should remove it, then just go with the polishing project as planned. If there is clearcoat present it will need to be removed before polishing.
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 06-13-2009, 01:19 PM   #3
Kevin245's Avatar
We always used rubbing alcohol on our old cars. It worked well for us.
William C. Swinney
Old 06-13-2009, 01:23 PM   #4
tinhutjohn
tinhutjohn's Avatar
1974 29' Ambassador
London , Ontario
Images: 8
I've always been able to remove just about anything with WD40 and it doesn't seem to effect the clear coat. I know that the Mother ship recommends it for removing the glue from theWBCCI decals and I've used it to that purpose. Give it a try. It's also good for arthritis of the knee or polisher's elbow.
74 Airstream Ambassador International
94 Burb Ontario plate "TIN HUT"
02 Jetta TDI
Logan the Large hairy Golden Retriever
It's a monocoque thing
You wouldn't understand
tinhutjohn is offline   Reply With Quote
Tree sap removal?? wyhjr Cleaning, Stripping & Polishing 32 03-05-2017 11:13 AM
Pine Sap Removal from Plasticoat Gator1 Clearcoat, Exterior Paint & Trim 9 08-07-2009 10:30 AM
Pine Sap Removal dwsafari Cleaning, Stripping & Polishing 15 04-10-2009 10:41 AM
Removing tree limb scratches? Brow324 Ribs, Skins & Rivets 8 11-03-2007 08:36 AM
removing scratches from tree branches millvalleyca Cleaning, Stripping & Polishing 3 08-06-2007 07:34 PM
