Old 11-24-2009, 11:27 AM   #1
67twinkie's Avatar
1967 26' Overlander
Lancaster , Kentucky
Removing rust and scratches
Wondering if there's any way to remove rust stains from the outer aluminum skin. The old rock guard latches rusted and ran down the front of the trailer. PO tried to remove the rust stains with something abrasive (sandpaper?), now the aluminum is scratched and rusty Any way to lessen the appearance of the scratches?
67twinkie is offline   Reply With Quote
Old 11-24-2009, 11:48 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Really the PO did not help your restoration. Your trailer has a clear-coat and if sand paper was used odds are the clear-coat and aluminum are damaged. If you what it gone it means stripping the clear-coat and polishing the aluminum to get the scratches out. There is a guy in Oregon that can do this and has had good results. I'll dig up the link. Found it. http://www.airforums.com/forums/f474...p-53238-2.html. There is DIY option Polishing. http://www.airforums.com/forums/f441/
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-24-2009, 01:08 PM   #3
67twinkie's Avatar
1967 26' Overlander
Thanks, Lee. We have already stripped the clear coat from the front panel and unfortunately the scratches are through the clear coat. Thanks for your help.
removing light scratches birwine Cleaning, Stripping & Polishing 3 07-07-2009 10:32 AM
Scratches! ...in clearcoat? iHayley Clearcoat, Exterior Paint & Trim 8 06-27-2008 03:58 PM
Removing tree limb scratches? Brow324 Ribs, Skins & Rivets 8 11-03-2007 08:36 AM
removing scratches from tree branches millvalleyca Cleaning, Stripping & Polishing 3 08-06-2007 07:34 PM
Scratches Pharmdawg Ribs, Skins & Rivets 1 08-30-2006 10:25 PM
