Old 04-02-2005, 04:14 PM   #1
removing roof coating
Does anyone know how to remove a painted on roof coating ? It was done by a PO who had no idea what he was doing . The coating was allowed to run down the side . I would like to remove this coating without taking the clearcoat off if possible . thanks
airtim is offline   Reply With Quote
Old 04-02-2005, 06:22 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
You would have to find out exactly what material the roof coating is. Then find out what material the clear coat is.
Now you could theoretically find a solvent that would attack the roof coating, not the clear coat.
However, on a 1975 model trailer, chances are that the clear coat is already blemished. Might be best to strip everything and then re-coat it with clear coat.
Uwe
www.area63productions.com
Old 04-02-2005, 09:43 PM   #3
Tinsel Loaf's Avatar
You could try masking the top paint and use fine sand paper to remove most of the paint. Repaint it with white paint to keep it cooler inside. That way you would have a nice roof without having to strip the clear coat. Ya know, once you start on the clear coat your gonna do the whole rig.
Tinsel Loaf is offline   Reply With Quote
Removing wallpaper from 76 tradewind Rennegarbe1 Upholstery, Blinds, Walls & Interior Finishes 4 02-05-2003 04:52 AM
Roof Air Problams ViewRVs Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 06:40 PM
Removing the Armstrong AC unit FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-02-2002 11:10 AM
Roof coating FrankR Roof 4 07-22-2002 01:56 PM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 01:35 PM
