Old 04-23-2004, 09:19 AM   #1
Beckley , West Virginia
Removing paint from my Airstream
Hello everyone...this is my first attempt to post on this forum so please bear with me. I recently bought a '69 Airstream Land Yacht which appears to be in reasonably good condition but it will need lots of work to get it into road-worthy condition. For some reason, one of the prior two or three owners, used aluminum paint on some areas of the exterior. I have no idea why one would do this but I need some advice as to how I get the stuff off. Any suggestions would be greatly appreciated. Thanks in advance, David
Blackjack is offline   Reply With Quote
Old 04-23-2004, 11:13 AM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Hmmm...I'm curious what's under the paint, bondo?
The problem you may have, is anything that would remove the paint will also remove the clearcoat, if it hasn't been stripped &/or polished earlier. That's no biggie if you are prepared to strip the entire trailer in preparation for polishing, but otherwise you will remove the paint & clear coat leaving the newly exposed aluminum to oxidize at a different rate than the area with clearcoat remaining. Over a couple of years (or quicker depending on your climate) it'll darken where the clearcoat was removed.
That being said, there are lots of different opinions on stripping & products to do so, I have found Kleen Strip's Aircraft Stripper (available @ WalMart, Pep Boys, Auto Zone, etc) to work very well. You can perform a search using the keywords "stripping clearcoat" and get lots of info on different products others have used.
If you use the Aircraft Stripper, be sure to wear gloves & follow all label instructions & warnings...it's nasty stuff!
Shari
Old 04-23-2004, 11:24 AM   #3
Thank you for the speedy reply. I had not considered that there might be bondo underneath but I would not be surprised. The seller (your proverbial good guy, grandpa) stretched the truth in several areas. Still, I think it is a good project and that I will get lots of enjoyment from it. David
Did Airstream ever paint trailers? 1972 Sneakinup Clearcoat, Exterior Paint & Trim 3 11-24-2003 07:14 AM
Can paint be removed from top of airstream? georgia888 Clearcoat, Exterior Paint & Trim 13 08-20-2003 12:38 PM
airstream! airstream! airstream! 83Excella Our Community 0 03-23-2002 10:37 PM
