Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 07-10-2007, 09:02 PM   #1
KHarris
69 Caravel
KHarris's Avatar
Profile:  1969 18' Caravel
Bayfield , Colorado
Removing old WBCCI numbers?
I am finally at the stage of polishing our 69 Caravel, and need to remove the old WBCCI numbers. I found refernces in the thread to removing numbers when the owner didn't want to damage the clearcoat, but that's not an issue for me. Should I tackle it with Aircraft Remover or citrus based stripper or Goo-Gone...any suggestions?
Thanks, Krista
I Dream of Airstream!
KHarris is offline   Reply With Quote
Old 07-12-2007, 11:29 AM   #2
mello mike
mello mike's Avatar
Profile:  1972 31' Sovereign
Phoenix , Arizona
Images: 22
I would think that anything
non acidic would work well like Goo Gone.
2003 Ford Excursion (6.0L PSD)
Prodigy / Equal-i-zer / Honda EU2000i / Xantrex Link 10
U.S. Navy (Retired)
Airstream Life Contributor
Air#5661 / WBCCI#--
My Refurb Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-12-2007, 11:37 AM   #3
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
Greetings Krista!
Even though you aren't concerned about the clearcoat, I suspect that any type of finish stripper may pose more problems than it solves when it comes to removing the vinyl letters. A heat gun makes quick work of removing the vinyl letters (a hair dryer will work, but MUCH more slowly) -- the adhesive would then be quickly removed with the stripping process.
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
Old 07-12-2007, 01:21 PM   #4
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
I vote for the heat process first, then clean up any residue with goo gone. I used a Dry iron and a towel to soften mine.
Aaron
WBCCI #2449 AIR #2495
Old 07-12-2007, 04:27 PM   #5
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
If you are just trying to remove the numbers before continuing on towards stripping and polishing your trailer, you can remove them with a heat gun as suggested, then proceed with stripping using the stripper of your choosing. We used Kleen Strip Aircraft Stripper on our '64, but I am using Citri Strip for the interior woodwork on our '56 - it's smells much better and doesn't take your skin off! I know others have used it on their clearcoat too.
The clearcoat stripper - whatever you use - should take off the "goo" and the clearcoat off at the same time.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 07-13-2007, 09:18 AM   #6
KHarris
69 Caravel
KHarris's Avatar
Bayfield , Colorado
Thanks!
Thanks for all the replys and helpful hints.
The heat gun did the trick of loosening the vinyl and the rest cleaned up with the Aircraft stripper. Scary stuff but works well when the citrus based solvents can't cut it.
Krista
Old 07-13-2007, 09:48 AM   #7
FreshAir
FreshAir's Avatar
Profile:  1966 24' Tradewind
Placerville , California
Gasket Remover works for me. It also loosens silicone too.
Neil and Lynn.
Neil and Lynn Holman
FreshAir #12407
Avatar;
Lake San Antonio, 10/07
'Thelma and Louise.'
1966 Trade Wind
455 cid
Old 07-13-2007, 10:01 AM   #8
peegreen
peegreen's Avatar
Profile:  1998 31' Excella 1000
South Berwick , Maine
I started using Goo Gone. Apparantly there are two different formulas. As you guessed, the bottle I had stripped the clear coat and didn't do much for removing the numbers. Will try the heat method next, back burner project.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 07-14-2007, 11:25 AM   #9
bevman
bevman's Avatar
Profile:  1958 22' Flying Cloud
Napa , California
I tried Goo-Gone but the vinyl keeps the liquid from getting to the adhesive. I used Jasco paint stripper. Found that the stripper softened the vinyl nicely. Numbers peeled off like harvesting a sunburn. The adhesive remained. Tried Goo Gone, but I've discovered a cheaper product -- just buy a gallon of Xylene at the paint store. (Goo-Gone is xylene + toluene).
The foil "caravan" sticker was harder. The foil had to be scuffed, carefully, with a wire brush so the stripper could get in there. The word "caravan" had long since disappeared leaving raw aluminum. Now I have "etched" letters there, as if sandblasted into the metal.
bevman is offline   Reply With Quote
WBCCI and local Units Stougard WBCCI Forum 58 02-28-2006 08:46 AM
WBCCI participation smily WBCCI Forum 206 01-08-2006 07:50 PM
WBCCI family/children/pet friendly? 1985air345 WBCCI Forum 66 01-08-2006 07:34 PM
WBCCI Survey smily WBCCI Forum 33 11-13-2005 09:08 AM
WBCCI Membership for free thenewkid64 WBCCI Forum 12 08-04-2002 12:10 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
