Old 03-17-2012, 08:48 AM   #15
Splitrock's Avatar
Sioux Falls , South Dakota
The best adhesive remover I've found is Goof Off. I get it at ACE.
Old 03-17-2012, 09:01 AM   #16
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Scrape as stated above, or lightly score with fine abrasive paper (CAREFULLY on the foil only) so the adhesive remover can penetrate. Then use Goof-Off, Goo-Gone, or any of the citrus cleaners will take off the adhesive.
Alan
Old 03-17-2012, 09:03 AM   #17
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
So far the 3M Eraser Wheel is the only thing that is working (sort of). Removing the adhesive is not the problem. It's the foil on top of it. If I can just get the foil off, then just about any adhesive remover finishes the job just fine. I'm making progress, so that's all I can ask for I suppose.
adwriter73 is offline   Reply With Quote
Old 03-17-2012, 09:09 PM   #18
"The East Coast"
DerOstkuste's Avatar
Beaufort , South Carolina
Right-Off makes goof off look like water.
It's just a hobby.......
http://felverdesign.com/vintage_camper_restoration
How well I have learned that there is no fence to sit on between heaven and hell. There is a deep, wide gulf, a chasm, and in that chasm is no place for any man. ~Johnny Cash
DerOstkuste is offline   Reply With Quote
Old 03-20-2012, 10:18 AM   #19
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Success! I got all stickers off. Here is the trick (as referenced by someone in this post):
1. Use a paint/adhesive rubber eraser wheel to remove the top layer or all of the sticker if you can. Picked this up at a local auto body paint supplier for $25. Uses a bit that fits into standard power drill.
2. Use paint/adhesive stripper to loosen or remove the remaining sticker.
3. If there's anything left, repeat the process.
Old 03-20-2012, 01:48 PM   #20
Splitrock's Avatar
Which one?
Old 03-20-2012, 10:04 PM   #21
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Originally Posted by Splitrock View Post
Which one?
I used Jasco. Picked it up at Home Depot.
Old 03-21-2012, 05:47 AM   #22
"The East Coast"
Just make sure no one uses Jasco on a camper with clear coat. Regular glue remover is all you need.
Old 03-21-2012, 10:44 AM   #23
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Oh good point! Yes. It will take everything off down to bare metal, which, in my case, was what I wanted.
Old 02-25-2013, 11:06 AM   #24
Mixter's Avatar
1976 27' Overlander
Old thread, but certainly relevant for me and others still needing help with this....
3M Stripe off wheel- it is simply awesome. Best $27 bucks money can buy: Amazon.com: 3M-7498 STRIPE WHEEL W/ARBOR: Home Improvement
Never knew there was such a tool, until a friend turned me on to it. Chuck it up to your drill and voila! Gone is the agony of trying to get that crap off with scraping and solvent. 5 minutes or less and your're done.
Mixter is offline   Reply With Quote
Old 02-25-2013, 11:20 AM   #25
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
The obvious issue is the glue is UNDER the foil, and until you remove the metal outer layer, you can't dissolve the glue....so I'd opt for a careful surgery with a plastic razor blade.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 02-25-2013, 11:29 AM   #26
Mixter's Avatar
1976 27' Overlander
That 3m stripe off removed it all for me. Best place is online- ebay has them for as little as $20 bucks. Locally they are $40+ here in Tampa
Removing window frames '61 GT streamahead Windows, Doors, Locks & Vents 3 07-30-2011 09:47 AM
Removing vent pipe without cutting? bennyg Ribs, Skins & Rivets 0 07-05-2011 04:42 PM
Need help removing rivets. Breadbug Windows & Screens 16 01-19-2011 08:11 PM
