I have found WD-40 to work wonders on those numbers as well as a number of other things including cleaning up Par-Bond and as a smoothing agent for Par-Bond ,just spray some on the tip of your finger then smooth it like you would silicone or other caulks.
The folks at the rally will probably understand if you did not have your numbers on the unit yet.
There are many folks that do not apply their WBCCI numbers to their unit.
I would wait until I polished the trailer and maybe even consider an alternative means of applying the numbers to something other than the polished skin of your unit.
Smily
__________________ Ken Smillie
My 1994 36' Classic MH is for sale See it in the classifieds
I just noticed today one of our numbers from the po on the front is coming off. How can I get all of them off. I was going to wait until I polished in the fall but it kinda looks tacky with that one peeling off.
Becky
75 Sovereign (Peppy)
03 Chevy HD (lil Peppy)
Air# 9552
wd-40 a plastic putty knife and careful use of a heatgun or hairdryer. It works. Also check to see if the same numbers are available and put the new ones directly over the old.
Keep the shiny side up. WBCCI # 3485 Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @ www.tidewaterwbcci.com
Rick Bell in "Silverbell"
there are several threads on the issues of removing the numbers......lots of info and frustration.
what ultimately works may depend on how long they've been on, what version of the numbers/adhesive and so on......
since you are gonna polish, i'll assume your plasticoat is toast or toasting.....
i suggest getting a thick old towel or now microfiber cloth or cheese cloth and wetting it completely with wd-40, then just cover the area for a few hours......no peeking.
wd should soften and loosen if given enough contact time and kept wet....
if this fails try a can of 3m general purpose adhesive solvent......same process.
let us know what happens to the red numerals.....and if shadows or imprints are left in your aluminum.....
cheers
2air'
__________________ all of the true things that i am about to tell you are shameless lies. l.b.johnson
Thanks for the tip. Yes 2air the clear coat there is toast. Already there are other number shadows there. I really dont ever plan on putting numbers back on unless I can talk my husband into some for next year since Perry is not to far from us.
Becky
Air# 9552
The swoopy graphics on our 96 Excella were unable to survive a Michigan winter and began peeling. They were fine as long as the PO kept them in sunny Arizona during the cold season.
The steam iron with the wet washcloth worked great to remove the decals.
This left many areas of sticky glue, but the WD-40 and lots of paper towels made short work of it without affecting the clearcoat. Unfortunately, the places where the decals peeled back removed the clearcoat during the peeling process, so the aluminum is oxidized there. I guess the decal just yanked it off the surface as it came loose.
So, we have some "ghosts", but no, I am not going over to the polishing side of the force. Once you start with the cyclo and nuvite, there is no going back.....
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
At least two po's removed the numbers from my '76 27' Overlander so I have at least two layers of Ghost numbers on the front and the back. It looks less than pleasing. Any advice on a simple way to "bust the ghosts" without going through the whole polishing process?
Does anyone know how to remove the numbers and circle decal that are on the front and rear of my '72 27ft overlander? I believe they are from the Walyy Club - we are not members and am not sure if I am ready to join. This is our 1st tin-twinkie and am getting an education on repairing what previous owners patched.
I tried just about every method mentioned to remove the numbers from my 61 Bambi with very little success. I tried a 2-3" round gum rubber wheel in my electric drill that paint and body supply stores sell for removing decals and pin striping from auto paint. Believe it or not, it took less than an hour to do both ends of the trailer. I do not believe that it would harm clear coat that is in good condition as it works well on auto paint.
I might have to try that wheel, as no other method here has worked on mine. The bottom layer of the glue from the letters is rock hard after yrs in the sun. I soaked with wd 40 and used other ideas here. I am trying the lighter fluid thing next though....do I need to light it ??? ( just kiddin) it might get it off then....
Rallys twice a year..Lots of fun, food, and aluminum.
Removing the numbers and decals should not be done with a hair drier. You can burn the plasticoat with it. Scraping the numbers will scratch the plasticoat.
The only tool you will need is a "steam iron." Take a wet rag, like a towel, place it over the number or decal, and place the steam iron on top of the wet towel, making sure that the towel stays wet. That will soften the numbers as well as the original adhesive. Then simply peel them off. Takes a little while, but does a great job, and causes no damage. I have been using this method for 36 years, and it has never failed. Andy
Does the 63 bambi have a plasticoat on the out side?
I took Andy's advice and used a steam iron and a moist cloth to remove the decals. I got most of it off. I finished with a rub wheel and went slow and made an effort not to ruin my clear coat. I got the numbers off but you can still see the numbers on the coach. Two shades of color on the metal.
